2012-2013 BOSS 302
No Sync in the Boss 302?!?!? WHAT?!?!?
Old 2/27/11 | 09:22 AM
  #161
OAC_Sparky's Avatar
Originally Posted by cloud9
Are you referring to the difference in engine weights between the Boss and GT500? If you've ever tracked a GT500, you'd appreciate losing 300-400 lbs from that front end.
No, I'm referring to the original topic of this thread.
ie, "NAV and SYNC adds weight"
I bought upgraded speakers for the '12 I have on order, I work for Ford, I'm well aware of the underwhelming speakers we put in the cars (it's not my decision, don't blame me). So now my car will weigh 15 pounds more than stock. That means that by most accounts I'm still ahead.
I'm surprised we don't have more horse jockeys as car racers.
Old 2/27/11 | 09:31 AM
  #162
4pipes's Avatar
Matt, where are the speakers in a Boss and are they a quick and easy replacement?
Old 2/27/11 | 09:45 AM
  #163
OAC_Sparky's Avatar
Well, assuming they're the same as the base Mustang stereo (which it's supposed to be) it should be a pair for the front doors and a pair in the back deck.
The doors are fairly easy if you're comfortable with removing trim panels (there are a few how-tos on the net). The rears are a PITA you have to remove the rear seat and the rear trim panels as the rears are bolted in from the top under the tray cover.
Personally I bought the Metra pigtails so I don't have to cut into the factory loom so it should be plug and play.
Old 2/27/11 | 09:48 AM
  #164
5 DOT 0's Avatar
I think the Boss only comes with coaxial speakers in the doors. More is better so I hope I'm wrong. From the order guide:
Audio – Premium AM/FM stereo w/Single-CD & Clock
Audio Input Jack
Old 2/27/11 | 09:51 AM
  #165
Big Vito's Avatar
I'm not getting a rear seat to remove
I thought it was the 4 speaker base radio in the Boss
Old 2/27/11 | 09:53 AM
  #166
5 DOT 0's Avatar
My understanding is Ford counts coaxial speakers as two speakers.
Old 2/27/11 | 10:04 AM
  #167
2012YellowBoss's Avatar
Originally Posted by phytrpilot
The single speaker was in the front. Like I said I'm an old guy that has owned Mustangs since '66.
I was lucky enough to be there on Apr 17, 1964 (not that I remember) made it back in 1989 for a party Ford had for the 25th anniversary. This car did not have Sync but it did have a 427
Attached Thumbnails No Sync in the Boss 302?!?!? WHAT?!?!?-67-wf-2.jpg   No Sync in the Boss 302?!?!? WHAT?!?!?-67-wf-1.jpg
Old 2/27/11 | 10:05 AM
  #168
LQQK's Avatar
If you replace the speakers, don't you also have to add an amp to drive them?
Old 2/27/11 | 10:20 AM
  #169
OAC_Sparky's Avatar
No, you're just going to be limited by the head-unit's power. However, better speakers than the stock Ford crappy speakers can be more sensitive and have better quality sound.
For example, the magnets on the back of the new speakers weigh 3x what the stock speakers do and are more sensitive. ie Less power to create louder sound.
PS. According to the Boss wiring schematics it shows 4 speakers, 2 front 2 back
Old 2/27/11 | 10:42 AM
  #170
5 DOT 0's Avatar
Cool. Are the rears coaxial as well? Looks like I need to replace four speakers not two.
Old 2/27/11 | 10:50 AM
  #171
Big Vito's Avatar
Replacing the speakers, you really don't know what the Boss is about
Old 2/27/11 | 10:56 AM
  #172
5 DOT 0's Avatar
I know I'm such a fool for driving my Boss on the street AND listening to the radio at the same time.
Old 2/27/11 | 12:25 PM
  #173
LateApex's Avatar
You should ask the Boss engineers just how much design time, thought, engineering, and money goes into saving 15lbs on a car. Any engineers, really, or racers, crew chiefs and designers, of nearly anything that moves. It isn't trivial. And it's because, all else being equal, the best mod for any tracked car is weight reduction. It simply makes everything else work better - speed, acceleration, handling, and braking. That's also why all race sanctioning bodies are obsessed with weight. If even minute amounts didn't matter, they would not be.
So while I wouldn't directly equate this with, say, using the Mona Lisa as a bathmat, it's somewhat the same concept, isn't it?
In any case, removing the stereo is some easy weight savings, and more permanent, too - the stereo won't sneak back into my car when I've eaten too much lasagna :-)
Old 2/27/11 | 12:39 PM
  #174
dean_acheson's Avatar
I'll get the better speakers, and throw out the space-saver in the back. Voila!
Old 2/27/11 | 03:25 PM
  #175
mycroft's Avatar
Pretty sure they don't make a spare that fits the Brembos. I'd guess you get a 1lb mobility kit (which is just tire slime and an air compressor).
Old 2/27/11 | 03:54 PM
  #176
OAC_Sparky's Avatar
The schematics doesn't say. But they don't show coaxials seperately in the Shaker schematics either. While Ford may count the coaxials separate speakers, electrically speaking they're treated as one speaker (the crossover is part of the speaker).
I guess you'll find out for certain when the Bosses start arriving unless someone with the base Mustang can chime in here if they have 2 or 4 speakers.
Old 2/28/11 | 08:01 AM
  #177
66sprint200's Avatar
{Observer's side note: I find it humerous that we quibble over a few pounds here and there and its effect on the track, and yet none of us talk about staying lean or about losing that 30 pound beer gut. And don't look at me, I weigh a sturdy 165 pounds)}
I didn't find it necessary until you mentioned it. That's why I ride ~100 miles per week on my bike and try to maintain somewhere between 155 and 160 lbs. A far cry from my collegiate 4.5% index but not bad for almost 50 years old...........
edit: I do tease my cycling buddies about spending $1k for the latest "carbon this" or "titanium that" just to shave 6oz ! Now that is when a little dieting can really pay off!
Old 3/20/11 | 06:54 AM
  #178
M3hunter's Avatar
Thumbs down
Originally Posted by FKA MotorCity Agent
Please tell me I missed something! Im looking at ordering a Boss 302 and I don't see Sync listed anywhere.
The sync is a piece of crap on my car, I did not bought my car because of this. I bought it because of the performance of this cars. In your case because it is a BOSS (a really great performance car for the price) . Maybe you want to better look for a Camry or a Civic.
Old 3/22/11 | 05:50 AM
  #179
valdeztke's Avatar
How many guys in here would opt for an OEM upgrade to HIDs though?
I understand the lack luster desire for SYNC, but I agree that an HID upgrade would be a big safety improvement for nighttime driving.
Would anyone be willing to sign a petition to ask Ford to offer this in a reasonably priced OEM swap?
Old 3/22/11 | 06:30 AM
  #180
mycroft's Avatar
Factory HIDs are more than just different housings, bulbs and ballast. There are a host of sensors for the self leveling mechanism as well. It wouldn't be an easy retrofit if you wanted to do it properly.
yabutt
10/23/15 01:05 PM
exgto
2012-2013 BOSS 302
10/7/15 01:47 PM
Quick Reply: No Sync in the Boss 302?!?!? WHAT?!?!?
