Forced Induction on the Boss...thoughts?? Please post
#42
#43
I hope your tank is properly sealed. Water content in the alcohol also raises octane, so other than losing some energy content, it's not all bad, especially on a supercharged motor.
#44
fyi, with vortec and boss intake manifold, you have to cut a section of the hood, the TB in normal position will hit the supercharger, so you have to flip it upside down, then it hits the hood.. a local guy found that out the hardway..
#46
Are you suggesting that a very small amount of water in alcohol, i.e. the reason people added alcohol to gas for years to absorb moisture in the gas, is a big deal? And back up your answer with some data so we can have a real conversation. As someone who injects a mixture of water and alcohol directly into my intake manifold, I am having a bit of difficulty in seeing an issue here.
#47
Yeah, and...?
![Screwy](https://themustangsource.com/forums/images/smilies/screwy.gif)
#48
I think what he wants to see is some data regarding how much more water would end up in a tank due to the gasoline containing ethanol, than a tank containing gasoline only and accumulating water from the air. I dont think he's arguing with you that it may attract more moisture, but the question is, how much, and is it enough to have any real detrimental effect.
If air is displacing the gas, you're going to end up with water in the tank anyways.
