Sponsored by:
Sponsored by: CARiD
Steeda lower springs problem - help
Old 12/27/15 | 06:27 PM
allen2016gt's Avatar
I put the sport lowering springs on my 2016 GTCS 3 weeks ago. When I hit a bump or pothole there is a thud sound from the front. Almost a bottom out sound? Any ideas!
Old 12/27/15 | 06:54 PM
SGwick's Avatar
If you have stock struts they may be bottoming out (hitting bump stops) = chassis sits lower so less/limits suspension travel (lower profile bump stops or stiffer strut setting could help)
Old 12/27/15 | 07:02 PM
houtex's Avatar
Stock shocks cannot handle the lowering. They are built to dampen to the stock height, and not just damp out the motion, like the aftermarket ones do. If you didn't swap them, well, swap 'em.
Old 12/27/15 | 08:43 PM
Which shocks do you guys recommend? W/o breaking the bank
Old 12/28/15 | 03:08 AM
07MRMIKE's Avatar
http://www.hypermotive.com/koni-str-...ock-set-05-10/
Old 12/28/15 | 10:14 AM
tj@steeda's Avatar
Hello Allen,
There could be a couple solutions here but would like to rule out that the springs were installed correctly. We have had a couple of instances where the springs were installed incorrectly & caused popping.
Also, it will be recommended to change out the mounts.
Please send me your contact info & let me know where you ordered the springs.
Best Regards,
TJ
badasbullitt
2/18/16 11:26 AM
GrnT
12/21/15 09:50 AM
Phobik
12/12/15 01:23 AM
allen2016gt
12/7/15 05:56 PM
deepstez
12/3/15 09:01 AM
