Steeda lower springs problem - help
I put the sport lowering springs on my 2016 GTCS 3 weeks ago. When I hit a bump or pothole there is a thud sound from the front. Almost a bottom out sound? Any ideas!
Stock shocks cannot handle the lowering. They are built to dampen to the stock height, and not just damp out the motion, like the aftermarket ones do. If you didn't swap them, well, swap 'em.
There could be a couple solutions here but would like to rule out that the springs were installed correctly. We have had a couple of instances where the springs were installed incorrectly & caused popping.
Also, it will be recommended to change out the mounts.
Please send me your contact info & let me know where you ordered the springs.
Best Regards,
TJ
GrnT
Dec 21, 2015 08:50 AM
