You're kidding, right? 2005-2009 & 2010-2014 Interior Door Panel Issues
Old Mar 19, 2023 | 03:44 PM
m05fastbackGT's Avatar
We'll be looking forward to your progress... I hope it goes well!
Old Mar 29, 2023 | 08:07 AM
AlloyPony's Avatar
It's been a couple of weeks and so far so good!
If it holds through the 120F summer heat index I'll be a happy man. We'll see....
Old Mar 29, 2023 | 05:10 PM
Good luck and hope it works out!
However, for those who have 2005-09 models, in my honest opinion, this product and procedure appear to be the best permanent fix for the door panel insert issues...
Last edited by m05fastbackGT; Mar 29, 2023 at 05:28 PM. Reason: Forgot to include video links
Old Mar 23, 2025 | 11:37 AM
bob_t442's Avatar
Living in Florida, I tried every glue in the book and the dealer was clueless on how to make the vinyl inserts stay on the door panels. I found a mechanically superior means to cure the problem. It involved stripping the panels of the factory vinyl, cutting a piece of Masonite to the shape of the insert, drilling the door panel and Masonite with matching pairs of holes around the perimeter of the Masonite. I threaded 22-gauge wire (common bell wire in one hole and out the other of the Masonite at each pair, I then glued polyester padding over the face of the Masonite and covered that with new vinyl that was large enough to wrap around the back of the Masonite well past the holes and between the wires. Prior to adding the vinyl, I decided to dress up the new vinyl with an embroidered Mustang. The final step was to thread each pair of wires through their corresponding holes in the front of the door panel and once all wire ends were accounted for, each pair was twisted together to secure the upholstered panel onto the door panel. I performed this fix/upgrade about 6 years ago and it's never failed since.
Old Mar 23, 2025 | 05:11 PM
@bob_t442
Would you mind posting some images, as I'm sure those of us looking for a permanent solution to cure the dreaded vinyl door panel inserts would be very interested in seeing some images of each step you took during your upgrade fixes...
Old Mar 26, 2025 | 03:25 AM
shaneyusa's Avatar
@bob_t442
Love to see those pictures.
Old Mar 26, 2025 | 04:32 PM
rocknrod's Avatar
Clean Machine Supercharged S-197 Member
Yes me too. I can't visualize that.
clucas
'10-14 Interior and Audio
68
May 31, 2014 08:34 PM
TxBoss23
2012-2013 BOSS 302
Aug 8, 2013 03:01 AM
wanted33
Sep 7, 2012 10:15 AM
Topnotch
Feb 14, 2008 07:09 AM
GRAYPNY
05-09 Interior and Audio Mods
Mar 1, 2007 10:33 PM
