Door Handle Installation Procedures
Actually, the SN-95 only takes about 10 minutes the way we do it, the S197 is the one that takes more like 45 minutes. Either one though isn't bad, at least compared to say, getting your gums scraped
Louie has the right page though, so you can go D/L the instructions there for most of our products (soon to be all)...
I had the Steeda ones for the SN95, so that was my comparison. With those, you had to take off the door panel, disconnect the handle from the cable, and then reconnect it. Sounds easier than it really was. Not really DIFFICULT, but definitely time consuming.
Yeah, we did it that way at first too, then I came up with a way to do it w/o removing the entire panel - works like a charm, and since we replace the shaft pin anyway, it's not a problem to cut the original while in place. Cable obviously still gets swapped over, but not a problem. The S197 is more difficult, but not as hard as it could be...
M3hunter
Sep 10, 2015 09:26 AM
