Wiper, High Beam, multi-function switch issues
Hi All,
I'm working with a 2011 Mustang GT.
Recently, the windshield wipers started randomly turning on despite the multi-function switch being in the off position. Many times, the washer fluid motor will randomly turn on too without warning.
The wipers will stay on in the high position; however, when I turn them off, they do not return to the bottom of the windshield, and just stick where they were, until I turn them back on or they randomly start going again. The intermittent wipers and low speed wiper setting does not work.
The other thing I've noticed is that the high beams wont turn on (when the multi-function switch is pressed forward), but the high beam flashers do work (when you pull the multi-function switch back)...so I don't think it is the high beam fuse.
So far, I've replaced the multi-function switch with a new one and the problems still persist. I've also checked the wiper motor fuse and it is OK.
I would much appreciate it if anyone can offer some insight as to what else could be causing the issue...I have no idea what other electrical components are involved with this system. Thanks in advance.
Ummm, that's a good one Raider. I wish I could help, so if you don't mind I'm going to hang around to see if someone else can help. You never know when on might need the same info. Good luck.
BTW, have you tried disconnecting the battery to reboot the systems in the car. I don't know if the wiper system is controlled by one of the compooters in the car, but it's easy enough to give it a shot..
I have seen this issue on older mid-90's Ford Rangers. On those the Multi-function switch on the turn sign lever was bad. Usually the Ranger switch would corrode and required replacement.
I think they had a recall on the Rangers back then...
The wipers are designed with the motor relays hard wired to the multifunction switch for high speed but all other functions (low speed, intermittent, and wiper parking) are controlled by microprocessor. This is a safety feature to ensure wipers can be used (only on high speed) if the internal microprocessor fails. If the microprocessor fails, you will have high speed wipers but no other speed and the wipers won't park when turned off - just as you describe.
I have found that water entering the cavity on the side of the wiper motor is causing my 'Stang's wipers to operate in 'ghost' mode. I found the rubber cowl drains plugged which allowed water to submerge the motor and harness connector. That was 3 years ago, happened again last week, when I found more water in the motor cavity (still original motor). Happened again yesterday, I'm ordering a tube of dielectric grease to fill the cavity and harness connector in attempts to banish the moisture. Fingers crossed.
Thanks For The Update!
These Threads in The 05-09 Section Should Be Helpful To Others With The Water Issues! There are More as Well in Section.
https://themustangsource.com/forums/...26-7-a-550617/
https://themustangsource.com/forums/...erleak-548040/
KC
KC
Wiper fix
Hi All,
Welcome & Thanks For The Tip.
Another Member With a 2006 Just Had a Similar Issue With His Wiper Motor and The Plug.
https://themustangsource.com/forums/...4/#post7088274
20 Years Down The Road on the S-197 and We Are Still Learning New Things!
We Appreciate The Added Info That Confirms The Wiper Drain Issue Ran in All the S-197-S From 2005-2014!
If You Like Do a Post in Our Introduction Forum & Post Some Pics of Your Pony!
https://themustangsource.com/forums/f650/
Thanks!
Kc Admin
Thanks!
Kc Admin
mustangmedstudent
Oct 31, 2021 08:56 AM
