Adding the OEM nav
Yeah I have the 2012 and 2013 wiring books. I only mentioned C210 because on my dash harness the wires are there for a rear sub and the backup camera and the go to c210. Just have to find money now to get the spoiler + paint, after I just dumped money for the nav install and money for a whole steering wheel just for 2013 (not 14) cluster switches and the nav switches.
Strange thing I'm experiencing with the climate controls.....
First, my center vents do not work at all. No matter what setting I push, either top vents, middle, or lower, no air comes out the center and side vents. When I push either the top or the center vents in the climate menu, air only comes out the defrost vents.
Second, I have tried both the original climate harness and the new one so the controls would not be reversed. However, with the original harness I only get heat at both ends of the temperature spectrum. With the new harness, I only get A/C.
Obviously, I have things plugged in the wrong spots, but there are only so many different combinations with the climate harness (and I tried them all). So I was wondering if there was something else there is to check?
Can anyone speak to this part specifically?
right steering wheel switches ($45) - AR3Z-9C888-FA. If you don't get this switch, the 'phone' and 'ok' buttons don't work.
I have a 13' Boss with the same buttons as those found in the GT/Shelby cars with navigation. Is this a part I need to purchase or will my current steering wheel buttons work?
Thanks,
Charles
Thanks,
Charles
Anyone have a known space where the GPS antenna works without having to install on the exterior? I was thinking under the dash between the two center vents, just concerned the dash padding may interfere with the signal.
Thanks!
Thanks!
I have my gps antenna in the back right between the seats. I didnt feel like drilling a hole in the trunk. The only problem im having is my SAT isnt working but my nav is fine.
Thank you. Are you referring to the rear deck lid or physically squeezed between the rear seats and the trunk access?
