Replace 5.0 badge with tri-emblem
Hope you know there are 2 alignment holes in the fenders. You'll have to center your tri-bar emblems over the "5" on the left fender and the "0" on the right one. That will give you a reference point for your tri-bar locations.
I used 60lb test flyline to cut the double-sticky tape. It took about 10 seconds or so to remove each one. Just ensure you cut it all the way through and remember there are 2 plastic alignment studs on the underside of the factory emblems. Once you remove the emblems and all the tape that remains on the fenders, clean them good and stick your new emblems on.
Here's what I changed to...
