Install of 2013-14 heated/pony projector mirrors
Old Feb 7, 2014 | 04:08 PM
joshuabowman's Avatar
So I wanted the comfort pack on my 2013 Mustang when I got it, however they did not have one in the color I wanted with it so I did without. After doing a little research I discovered that my 2013 Mustang Gt had the wires for the Mirrors and pony projectors. I call Tousley Ford up and Ordered a pair. $325.00 Shipped
SO on to the install. The tool required is an 11MM wrench and 8" flat tip screw driver
First roll your windows down and adjust both mirrors all the way down.
Once that is done pull on the top corner of the cover panel with your fingers and you will notice a small gap appear. pull this cover off.
Disconnect the gray plug from the mirror adjust switch and set the panel aside to reveal the mirror plug and 3 11mm nuts.
Disconnect the black mirror plug.
loosen the three 11mm nuts with your wrench. While supporting the mirror with one hand remove the nuts.
once you have removed the 3 nuts remove the old mirror and replace it with the new one.
while supporting the new mirror reinstall the 3 11mm nuts and tighten. install the black plug into the new mirror and watch as the pony projector comes on.
Reconnect the gray plug and snap the cover panel back onto the door. Now all you need is to get your outer mirror cap onto your new mirror. this is why you need to move your mirrors all the way down so that you can access the 4 taps. You can remove the glass assy to make it easier. this is what it looks like with the assy installed.
once the glass assy is removed you can get to the four tabs. 3 along the top and one on the bottom inboard side. (the picture below is upside down)
once the cap is removed then you snap it onto your new mirror and move on to the passanger side.
The passenger side is the same except you don't have to worry about the mirror adjust switch.
Very happy with how easy this was and it only take about 30-40 mins for the swap.
Old Feb 7, 2014 | 07:52 PM
dmhines's Avatar
Cool. Wasn't that easy on my 2012.
Old Feb 7, 2014 | 08:54 PM
stang8psi's Avatar
why?
Old Feb 7, 2014 | 11:44 PM
jp1seattle's Avatar
Originally Posted by stang8psi
why?
Probably because the connector wasn't already in the mirror ready to be plugged in.
Old Feb 8, 2014 | 06:15 AM
Gabe's Avatar
Plug and play, gotta love it!
I think you just made me spend another $325 on my car, lol
Old Feb 8, 2014 | 07:37 AM
Joeywhat's Avatar
Anyone know if the wiring is there on the V6 cars? I'd really like heated mirrors...and that isn't a bad price to get them.
Old Feb 8, 2014 | 11:14 AM
CiniZter's Avatar
nice thread... i had a question... could u make pony logo run with my park lights
Old Feb 9, 2014 | 12:19 AM
VancouverV6's Avatar
If your car is 2013+ then the wiring should be there. My friend did it on his 2013 V6 and it was plug and play.
Old Feb 9, 2014 | 12:37 AM
Joeywhat's Avatar
Nice. It's a 2014 (on order). Good to hear this can be done cheap, I love heated mirrors.
Old Feb 9, 2014 | 02:00 AM
TheDivaDanielle's Avatar
and here i am with the passenger side puddle light out and i haven't even cared enough to get it fixed yet.
Old Feb 13, 2014 | 09:06 PM
Rocket's Avatar
Are the Pony lights on all the time??
Are the heated mirrors on all the time??
Old Feb 14, 2014 | 05:26 AM
Gabe's Avatar
The pony lights come on when hitting the unlock button on the remote or when opening the door
Heated mirrors work off the rear defroster button
Old Feb 14, 2014 | 06:17 AM
Rocket's Avatar
Thanks I will make the change they are very cool.
Old Feb 18, 2014 | 01:21 AM
onequickstang's Avatar
I have been trying to figure out how to do this! Thank you!
Old Feb 18, 2014 | 07:32 AM
bones302's Avatar
I wouldn't rig it so the pony projectors are on for an extended period of time, like with the parking lights. the heat sink is subsantial because they get REALLY hot when they're on. if you rig it up that way they will likely fail prematurely and you will be replacing them pretty often.
Old Feb 18, 2014 | 07:38 AM
Tapakegovagnaps's Avatar
Does this work on all trim levels?
Will it work on the base gt?
Old Feb 19, 2014 | 08:17 AM
DeeJayTJ's Avatar
yeah id like to know the answer to this as well!
Old Feb 19, 2014 | 10:27 AM
My friend has a base GT and it works on his. Quick way to check is to pull the cover on the drivers door off and see if you have four or seven wires going to your mirror. If it's seven it should work.
Old Feb 19, 2014 | 10:29 AM
No problem, glad I could help.
Old Feb 19, 2014 | 07:01 PM
centexstang's Avatar
I know some may think the projector mirrors are a joke but I like them. Good write-up.
