Sponsored by:
Sponsored by:
Trouble hooking up
Old Apr 28, 2014 | 10:41 AM
slow.stang's Avatar
Trouble hooking up
Just put a vortech on my car and took it to the track, what a joke. 1st and 2nd gear are useless with my current setup. I have 265 F1's on the rear and my car is lowered. My next step is an adjustable panhard rod to align the rear end, I was also considering putting my stock springs back up front to help shift some weight to the back. I want to hook up, but not hard enough to break something. Any advice here?
Old Apr 28, 2014 | 10:45 AM
slostang's Avatar
If you think you can run a junk *** F1 on a 600ish rwhp car at the track and change a panhard bar(should be on already, it's lowered) then I think you need to hit the drawling board.
Auto or Stick car?
If Auto run a M&H racemaster
Manual pick a nice soft wall tire, I run a hoosier.
Old Apr 28, 2014 | 10:50 AM
slow.stang's Avatar
Hey, nice name. I'm aware about the panhard bar, just been putting it off. I don't think the F1 should be able to handle it, but I can't even run 1st and 2nd at half throttle. This is my daily driver, what would you recommend as a street tire? It's a stick, what else besides the obvious(tires) would help me?
Old Apr 28, 2014 | 11:13 AM
slostang's Avatar
I would do LCA/Upper and a NT05 if you drive the car as a daily.
Old Apr 28, 2014 | 04:12 PM
kona stang10's Avatar
Mickey thompson dr's !!
Old Apr 28, 2014 | 05:10 PM
Match.com
Old Apr 28, 2014 | 05:45 PM
tj@steeda's Avatar
Yes ... you need to beep up that suspension & plant that rear end.
If you would like ... we can put a package together for you ... you can send an email to tim@steeda.com. Let me know your budget & we can see what we can get you into.
Best Regards,
TJ
Old Apr 28, 2014 | 06:34 PM
Ltngdrvr's Avatar
Nothing short of drag tires will come close to getting the power down, heck, even stock you can't put the power down on street tires.
Old Apr 29, 2014 | 06:30 AM
slow.stang's Avatar
Originally Posted by 2k7gtcs
Match.com
Buy you're right here
Old Apr 29, 2014 | 06:35 AM
Best Regards,
TJ
wouldn't it be more helpful to all if you made a suggestion here in this thread?
Old Apr 29, 2014 | 10:44 AM
tj@steeda's Avatar
Knowing the budget helps us assist the situation. As a courtesy to the OP ... we ask to be emailed because we can respond much faster via email than logging in and finding the threads we have already responded to.
He should run our Adjustable UCA, 555-4112, UCA Mount 555-4027, Lower control arms 555-4405 and LCA relocation brackets, 555-8119. That will get the weight to transfer on to the rear tires and get the car to hook. (Some drag radials would help too) Also getting weight off the front of the car with our lightweight radiator support. 555-5080
Best Regards,
TJ
Old Apr 29, 2014 | 11:42 AM
slow.stang's Avatar
Best Regards,
TJ
Thanks TJ, are your suggestions in order of importance? I'm not looking to make it a drag car, but I feel I should be able to get in it a little on the street without total chaos. I have no desire to drive on drag radials everyday though. I will take a look at your site and check these items out, maybe if I hit the treadmill I can take a little weight off the front.
Old Apr 29, 2014 | 12:51 PM
point taken TJ.
Do you guys also carry the K member for the 5.0's?
Old May 2, 2014 | 12:13 PM
tj@steeda's Avatar
The k member that we have is for the 96-04 Mustang.
Best Regards,
TJ
Old May 2, 2014 | 12:14 PM
tj@steeda's Avatar
Yes, the lower control arms will help you greatly.
Best Regards,
TJ
Old May 3, 2014 | 11:02 PM
Five Oh Brian's Avatar
A proper drag radial with a tall sidewall is all you need to hook up. Okay, maybe an adjustable upper rear control arm if you have axle hop. Otherwise, you should be good to go.....
Old May 4, 2014 | 07:25 AM
I echo the drag radial solution. It works. I know from experience.
JonathonK
Which is Better
Nov 17, 2017 12:02 PM
mx5jhb
Sep 30, 2015 04:44 PM
PonyMuscletang13
Sep 29, 2015 09:40 AM
Airborne42
Sep 25, 2015 05:14 PM
BigHoss
Sep 21, 2015 10:03 AM
