Kenne Bell Coyote
#41
heck I might do like blackgt87 is doing and I could even secretly record a video while I do it and have a vid walkthrough!! OMG that would be priceless. Heck I may even do the video of her refusing me and post it to YouTube, then she will divorce me and then I get the SC, BAM!!!
#42
G4M3 0V3R
#44
Most of the clutch was burned up before my blower. Only had blower on for about 50 miles when I swapped clutch. With bolt ons I trapped at 116. Car is now making 650 & 530 with procharger d1 @ about 10psi. I live in Chicago and blower went on this winter so won't have any times till may.
Thanks.
#46
Originally Posted by Hytek
When she gives you the ok, please post a write up on how you got the wife to let you buy a supercharger.
#47
Originally Posted by El Fufi
Yep. I think the guide on how you convinced the wife would be more valuable than the guide on how to install it.
More timing is needed to make power on the NA setups, but you can run much less timing with a blower while still making gobs of power.
$7k to build a motor when the NA one let's go, or $7k for a blower to keep the motor intact with an extra 200 horsepower.
You're welcome.
#48
#49
NA motors blow the #8, FI motors are fine.
You're welcome.
You're welcome.
Guess I am a little confused, are you comparing the addition of tunes and CAI's to make more power to adding a blower to make more power. And how the tunes for the CAI can have more impact than a SC? Doesn't a SC need a tune also, Sorry just a little confused and want to understand this better
#50
Bolt on cars with intake and exhaust for example need a lot of timing to make power.
FI cars, supercharged, don't need the same amount of timing.
Timing is what has hurt these motors. That and adjusting the factory knock settings.
You can make more power with less timing with a blown application.
#51
No question but, the massive cylinder pressure increase of high output blower and nitrous apps is going to eventually put a chicane in the rods, too. I think the tune and CAI issue has been pretty overstated. We're talking a couple cars out of thousands and thousands. It's a far bigger data set, I bet, than is currently available for SC on these cars, because of the massive price differential.
redrock35
05-09 Exterior Modifications
7/31/16 08:50 PM
BavarianStang
9/5/15 05:55 AM
Detroit Steel
2007-2009 Shelby GT500
8/17/15 02:29 PM
