Sponsored by:
Sponsored by:
Boss 302 Side Exhaust Install/Discussion
Old Jun 28, 2012 | 07:55 PM
  #201
Nokternal's Avatar
I think I unthreaded everything and put the bolt through the bottom to gain access to it.
Im sorry but, um.. HUH??
oh and, um... how?
Old Jun 28, 2012 | 08:13 PM
  #202
Overboost's Avatar
oh and, um... how?
I'd have to look at it. I thought they had two rectangular threaded blocks that drew together to tighten the joint up. I simply took everything apart, then put it back together with the bolts facing downward, instead of up towards the body. The clamp is welded in place IIRC, so you have to flip the fasteners to make it all work. Not hard at all.
Old Jun 28, 2012 | 08:45 PM
  #203
Nokternal's Avatar
My problem is I can't even get at the bolts to take everything apart in the first place. I was under there for 45 minutes tring to remove one bolt before I threw in the towel.
Old Jun 28, 2012 | 08:50 PM
  #204
Overboost's Avatar
I did this with the old exhaust off of the car. It took me a combination of wrenches to get in there and get it out. I actually seem to remember a torx or star tip at the end of the bolt that I think you can use to back it out.
Old Jun 28, 2012 | 09:21 PM
  #205
MRGTX's Avatar
I looked at the wrench clearance and said "eff- it." My dealer installed the Boss H pipe for one hour worth of labor while it was in for an oil change.
Old Jun 28, 2012 | 10:42 PM
  #206
Nokternal's Avatar
Seem like a waste to pay someone else for what should be such a simple install just because I can't get two little bolts out. God this is frustrating
Old Jun 28, 2012 | 10:57 PM
  #207
Nokternal's Avatar
On a side note, while I was under there today I looked up at the connection where the pipes are bolted together right ahead of the cats. There are flange things sticking out that look a hell of a lot (to me) like they could be baffles similar to the restrictor plates used in the side pipes from the boss. They are very thin and I can't figure out why they are there.. could this be some kind of easily removed restriction built into the exhaust?
Old Jun 29, 2012 | 01:49 PM
  #208
MyStang2010GB's Avatar
Had the dealer installed mine today. Ramps and my tools weren't cutting it..
Car sounds so much better !!
Old Jun 29, 2012 | 03:53 PM
  #209
Nokternal's Avatar
What did they charge for the install?
Old Jun 29, 2012 | 03:58 PM
  #210
1 hour labor cost.... $95. Deal for them as it took only 40 minutes
Old Jun 29, 2012 | 04:14 PM
  #211
Overboost's Avatar
For those of you DIY installers, any suggestions on installation? My plan is to remove the H-pipe, install the new one, pre-assemble the side leg pipes, then bolt those up and on, then realign the over axle pipes and axle backs (mine need some slight tweaking anyways).
Old Jun 29, 2012 | 05:11 PM
  #212
06GT's Avatar
The side pipes come pre assembled. You will need to remove the gas tank splash shields on both sides. Your plan is good. H pipe connection is flexible so it can be frustrating for one person. Have sometimes help you if possible.
Old Jun 29, 2012 | 06:11 PM
  #213
Nokternal's Avatar
Any advice for how to get the stock H pipe uninstalled? The installation of the new one looks like the easy part. Getting the old pipe off is proving damned impossible. I was out there for two or three hours trying to work those front bolts loose today and I didn't even budge them.
Old Jun 29, 2012 | 07:08 PM
  #214
Overboost's Avatar
I've got a friend helping me with it tomorrow. Do you have a picture of the splash shields or is it painfully obvious what needs to get taken out? Also, the fasteners that secure the side pipes to the body, are those a multi part fastener, or some type of grommet with a nut to hold them in place?
Old Jun 29, 2012 | 08:58 PM
  #215
06GT's Avatar
It is all obvious. Just mock it up and you will see
Old Jun 30, 2012 | 12:49 AM
  #216
Overboost's Avatar
Its sitting on the floor of the living room waiting to go on later. I see it came shipped with some caps on the H pipe sides, which I'm guessing houses the restrictor plates.
Old Jun 30, 2012 | 05:53 AM
  #217
MRGTX's Avatar
Congrats!!!
No restrictors, right?
Old Jun 30, 2012 | 01:43 PM
  #218
Overboost's Avatar
Got mine installed today. Had a bit of trouble with a clamp on the old H pipe, but the new one went in smooth. Absolutely love the sound. Off throttle, it has a great burble that I really like. Can't wait to spend some more time with it later at the cruise.
Old Jun 30, 2012 | 02:13 PM
  #219
CaptDistraction's Avatar
Awesome. 06GT handled the install on my car, the sound is fantastic.
Old Jun 30, 2012 | 02:38 PM
  #220
06GT's Avatar
Downshifting to every stoplight now...
