Performance And Tech
#521
Shhh...
#522
Ok so I think my next mod will be the anti roll bar radiator support eliminator. Then the waterpump. Then delete plates. In that order. Anyone else have any mods planned in the near future. I will order the support brace in the next couple weeks I suppose.
#523
line loc install, except they left out the wire in the kit. so i have to pick up some 18' wire and some connectors or wait for them to send them to me.
david, you can take my car for a spin and check out the sway bar delete if you want
#524
David... let's make one...
#525
#526
Get on it Pauly!
#527
This is what I'm saying...
Now that's it getting cooler i need to try out the welder.
#528
We would most likely need a tubing bender of sorts I think?
#529
just sneek over to carFX and have J-Rod (in his chester cheeto outfit) run inside and steel will's.... that sounds pretty simple to me. lol
#530
Don't know. Have to look...
#531
Really all it does is support the radiator after you remove the heavy one from the factory.
#532
you dont need a support for the radiator.... gosh
#533
Sure. It will work just fine scraping the ground.
#534
it wont scrape the ground.... I read it in a magazine
#535
Huh?????
#536
one of the mags took off the front swaybar somehow without putting up any support.... they did this at the track for testing
#537
forget the brace.... just duct tape and superglue the radiator to ur hood.
#538
Well you can remove the swaybar. But its the support brace that removes the weight. It weighs like 45 lbs. THis is the piece that supports the radiator. It's the whole reason for removal.
#539
not the whole reason .... the sway bar must weight at least 20lbs
#540
I think it weighs like 8 lbs it is hollow from the factory.
