http://www.pro-dyno.net
Dynojet $50 for 3 runs with A/F Uncorrected 275.01 RWHP and 298.94 Torque.:jester: Corrected 266.62 RWHP and 289.84 Torque. :banana: 06 GT Manual Vert, Stock. |
Just got a new custom tune from Steve at Powertrain Dynamics!
307 rwhp 330 rwtq will post dyno sheet once I get back to work |
2 Attachment(s)
I know it is only a V6, but I was pretty impressed by the results.
2006 V6 5 speed auto RWHP 188.84 RWTQ 204.81 Current Performance Mods: FRP X-pipe /w GT takeoff Mufflers American Muscle 93 octane tune Comming Soon: JLT intake Bama Chips Custom Tune Anyone have any ideas about the Blip about 5400 rpm? It did it at the same place on each run. |
Originally Posted by bee bop
(Post 819921)
Anyone have any ideas about the Blip about 5400 rpm? It did it at the same place on each run. If the lower scale was time instead of RPM the bump would be a hump. Plotting RPM, it shows as a loop because the RPM goes up and drops back quickly. |
Stock with 20's, just pulled this today.
267.77 RWHP 284.72 RWTQ Now the fun begins. :banana: |
Originally Posted by mdcorny
(Post 835411)
2 Attachment(s)
Here is my run sheet, custom dyno tune from VMP Tuning.
Mods were C&L Racer, CMCV DP's, UDP's, ARH 1.75" primaries LT's, O/R X-Pipe, and Zoomers A/B exhaust. 321.79rwhp 228.53rwtq It was SAE |
My First S/C numbers
2 Attachment(s)
My "starter" tune for the winter.
441.29 RWHP 407.66 MAX TORQUE SEE SIG FOR MODS. |
Kurgan Motor Sports just did one of our turbo kits on an 05
538hp 587ft/lbs You gotta love the torque of a turbo 11psi pump gas http://www.granatellimotorsports.com...yno34small.jpg |
271 rwhp / 425 rwtq SAE corrected.
KB 2.6L, Bassani axle-back, 8.5 psi, Mustang dyno http://i93.photobucket.com/albums/l4.../finaldyno.jpg |
Originally Posted by StreamlineGT
(Post 851817)
KB 2.6L, Bassani axle-back, 8.5 psi, Mustang dyno :grin: Understand it's a typo. Should say 471rwhp according to your sheet :nice: |
2 Attachment(s)
New Numbers,
I will get the pictures later, but here is the dyno sheet. We retuned at MPH because of check engine light (Lean both banks). I believe that this may have been related to the Roush exhaust on my Sport. Anyhow, after inspecting everything, we found no issues with my install. Tuining went smoothly as MPH has done Beta testing for KenneBell and installs a number of these units weekly. Kit was installed as supplied from KenneBell including IC and 8lb pulley. The only additions were HT0 plugs and the X-Cal2 and tuning. There are better dyno results out there, but I went conservative since this is actually my wife's daily driver! http://www.fnsweet.com/forums/images/smilies/eek.gif Ask any questions and I will try to answer them. Paul |
did 3 runs on a Dyno Dynamics to establish my baseline before the H.O Whipple goes on :)
pulled a 302.4RWHP i just noticed my chart has horsepower, tractive effort and speed in kph rather than rwhp, rw torque and RPM :( kinda useless anyway here goes: http://img504.imageshack.us/img504/1156/dyno2kp5.th.jpg Dyno run video |
2 Attachment(s)
404 RWHP and 354 Tq @ 11psi on a tune not optimized for heads/cams.
http://flapjack.yi.org/website/image...heads-cams.jpg I've since upped the boost to 14psi, and cleaned up the tune a bit, but there's still some work to be done. Doug likes keeping his email tunes a bit on the conservative side since he's not actually there looking at the car. Hopefully one of his trips will take him through CO and we can see what this car will really do. |
Holy Smokes,
That is definately one 6cyl that will wake some folks up! :metal: Good Job Paul |
anyone looking for any deals on 05-07 parts and did you hear I am racing again - sadly not an 05-07 car - here is a link
www.granatellimotorsports.com |
Yea.. I saw you make a run.. I was working the NMRA Event both Sat & Sunday..
2 Attachment(s)
480RWHP 515WTQ 16degrees timing AFR never goes above 12 so this is on a very conservative tune 11# boost Power House Turbo Kit everything esle completly stock. :doh:
Nice to see another GA car. Tim tuned my car a couple of months back.
Originally Posted by pachary
(Post 861388)
New Numbers,
May as well throw mine up. My first and only dyno run to date. This was done before the UDP install. As you can see on a Mustang dyno. I was happy given this was done w/ nothing but the C&L CAI and 93oct Brenspeed tune.
Computer said 287 rwhp / 304 rwtq Sheet says 286 rwhp / 303 rwtq http://i19.photobucket.com/albums/b1...eet286-303.jpg |
| All times are GMT -6. The time now is 07:53 AM. |
