Just had the tune finally optimized for the heads and cams, as well as for the altitude. The results are in SAE. A DynoJet with the latest software read 6 HP and 3 Tq off from the SuperFlow.
From now on, I'll be doing all my tuning on the SuperFlow. I feel better knowing that it implies load to simulate road driving conditions. I'd hate to have zero detonation on the dyno then turn around and get det on the road. Anyways, here are the results @ 6600rpm: http://flapjack.yi.org/website/image...no/440RWHP.jpg Here is the DynoJet run @ 6300rpm. Pretty **** close. Probably would've been even closer if I had run it up to 6600rpm. http://flapjack.yi.org/website/image...HP_DynoJet.jpg |
Wow, you GT guys have some sweet numbers. I'm pretty much at the limit of what my stock short block will do. I may try a small shot of nitrous to push me over 500 RWHP, just to see if it'll do it. Other than that, my focus is now the track.
I'm putting on double-adjustable UCAs, rear sway bar, anti-squat brackets, k-member brace w/engine torque limiters, double-adjustable aluminum panhard bar, T/A girdle, 7.5" axle brace, etc... I want to see what the stock 4.0L and stock 7.5" do before they explode. :) |
There should be a Dyno Queen chart like they have for the 1/4mile runs. :banana:
FRPP Axleback, JLT CAI with sct 93 tune on Mustang Dyno
326 rwhp, 325 torq |
Originally Posted by mike05gt
(Post 882172)
Originally Posted by flapjack
(Post 882253)
Not bad for N/A on a Mustang Dyno!
(Post 882262)
This was back in November temps were cool 60 degrees, stang has 23000 miles and runs on amsoil synthetic oil
(Post 882265)
Congrats. I'm starting the next stage of craziness soon. Nitrous is on order. If this doesn't blow the engine, I don't know what will. ;)
(Post 882270)
Good luck on your next stage :nice:
N/A: JLT intake, pullies, delete plates, offroad H, custom tune: 303/318
F/I: Vortech V2, delete plates, offroad H, custom tune: 439/383 |
263hp/286tq - DynoJet
http://www.youtube.com/watch?v=dqyV2oeRaoA 2007 Bone Stock manual with 1,650 miles on the clock. |
Video of my Dyno pull.
http://s119.photobucket.com/albums/o...nopull4-21.flv |
Dyno Dynamics Dynamometer
Baseline: 272rwhp Best N/A Pull: 302.4RWHP, 332.5RWTQ (click for Video)
Originally Posted by G.T
(Post 898892)
Originally Posted by PIKE2244
(Post 899003)
Good #'s! Question though; to get 302.4rwhp / 332.5rwtq are the only mods you had the JLT Cai & SCT Tune?
The Dyno Dynamics numbers are generally higher than others by a few rwhp. |
Do you have any idea by how many rwhp it deviates?
(Post 899178)
usually ranging around 260-265rwhp so it's about 10-15rwhp higher than a dynojet |
2 Attachment(s)
Custom tuned by Justin at VMP TUNING on his Dynojet (load capable)
440 hp / 421 trq Vid of one run http://i66.photobucket.com/albums/h2...h_MVI_0486.jpg Dyno sheet |
2 Attachment(s)
Wow.. I forgot this thread even existed. Amazing what a difference two years makes :)
Saleen series VI twinscrew, 3.4" 9.5psi pulley, GT Supercar fuel pump, 40a BAP, 39lb injectors, Kooks headers, Kooks hi-flow cats, 4.10 gears, Meziere electric water pump. Custom tuned by HPP Racing, running 93 pump gas and only 17 degrees of timing. 500.9 rwhp SAE corrected on a dynojet 469.7ft lbs rwtq |
