2 Attachment(s)
2007 GT
Whipple 500 H.O. Mac Axle Back 'Safe' Tune 493rwhp 437rwtq |
304rwhp 358rwtq @7200ft elevation
mustangdyno K&N FIPK, 3.73 gears, Hamburger's 1" throttlebody spacer, SCT Tune from Brenspeed on 91 octane. 93 wasnt available. :( and its also an automatic. not bad I want to get to a lower elevation to dyno it but havnt had the chance yet. |
Andrew , if you're getting that much rwtq , you must be pleased ...
Originally Posted by flapjack
(Post 985711)
That's fine, if that's what you want. To me, even a properly sized turbo has too much lag for me. I love the way a centri "builds" boost. I'm not saying a centri is "better", because it's not. It's just a personal preference.
Still, with a good tune, even a turbo-charged or posi-displacement blower can last a long time. Even at 9psi.... Remember - my back ground is in Centrifugal Supercharging. I owned Paxton Superchargers from 1992 to 1998. I designed and pioneered the Novi 2000. I know the strengths and weakness of the centrifugal |
Originally Posted by Granatelli
(Post 1041851)
http://www.granatellimotorsports.com...507_smallb.jpg
http://www.gmsvideos.com/video_detail.php?mId=1417 - 617hp / 646 ft/lbs http://mustanglife.tenmagazines.com/...ticle&aid=3275 Ok its bad enough you have that crazy Canadian in the car but PLEASE get rid of that cheesy music!?!? |
Originally Posted by 05YellowGT
(Post 1056184)
Hey JR, are you working on a CARB approval for your turbo kit?
Here are my Numbers at the rear wheels
HP = 402.2 Torque = 396.4 Mods: 2006 Saleen Supercharger with 475 HP upgrade, 6 PSI Boost Injectors: 39 lbs, Dual GT fuel pumps, Custom tune SCT X3 AF ratio = 11.8-12.0 max |
Originally Posted by SpeedRacer
(Post 1056902)
Hi Guys here's my numbers on a Mustang dyno
405 rwhp 369 Trq Saleen 3.5 pulley, 95mm Maf, 39 lb injectors, WMS intake, GTA mufflers. 2005 GT Manual 3.55 gears. |
451 RWHP, 432 RWTQ @ 60 degrees F.
A/F is lean, but I may get a custom tune soon to correct it. Kenne Bell, 8 lbs. boost, GT500 dual pumps, FRPP shorties & 4.10s |
Originally Posted by Enfynet
(Post 677735)
289rwhp 306rwtq
C&L Racer intake, o/r H, flowmasters, Brenspeed SCT tune. http://www.youtube.com/watch?v=uG4X-jhcQ3E |
I see some guys with GT's posting numbers below 300
pardon my ignorance but i thought GT's perform 300 hp is that just a number with no guarentee? |
Originally Posted by anteyeiabazele
(Post 1070952)
15% is an average for all cars, I think the manual mustang is probably closer to 12%.
2 Attachment(s)
577 rwhp 519 rwtq with a whipple @ 16psi, stock heads, stock cams, long tube 1 3/4 primary to 3 inch collector, PI 3300 stall converter, 5 speed AUTO transmission.
Already turned a 10.77 @ 125.82 mph at Famoso on 511 rwhp, so we will see what 577 rwhp is good for on January 20th. http://videos.streetfire.net/video/6...0c00fa742a.htm |
4 Attachment(s)
Originally Posted by topoffGT
(Post 1067812)
A/F is lean, but I may get a custom tune soon to correct it. Kenne Bell, 8 lbs. boost, GT500 dual pumps, FRPP shorties & 4.10s Got a custom tune from Dan @ Pro Dyno. :hail: Changed to a 10 lb. pulley (3.75 inch) New numbers are: 497.52 RWHP & 452.09 RWTQ |
272/295 bone stock. all the way down to the gas ford filled my tank with.
'07 black GT. current performance mods are steeda underdrive pullies. should have a c&l intake and some mail order tunes once i get some money. |
I'm curious the type of dyno, Mustang or DynoJet? Also, do you have a manual or auto trans?
Thanks, Dave Kegel
Originally Posted by Speeddmn
(Post 1083230)
Originally Posted by dkegel
(Post 1083672)
Thanks, Dave Kegel |
