2 Attachment(s)
For the record...
2500km, manual 07 GT, 279.66 PS, 397.61 Nm. Bone stock |
Hi, this post is very informative; however I would like some specific information. If someone can help me then please send me a private message. Best Regards,
Baseline run: '06 Mustang GT convertible, stock except for Hurst shifter.
SAE corrected: 273 hp, 299 ft-lbs. That was about 8 hp more than I expected from the stock motor. Next up: JLT CAI w/Bamachips tune. http://TheDarkHorse.info/hold/2007-04-21_Dyno.gif |
Good #s.
Other TMS member manual 5-speed, dynojet dynoed, stock GT #s for comparison. RWHP RWTQ 272 288 270 273 296 271 295 273 295 275 291 276 293 263 286 267 290 266 280 |
2 Attachment(s)
Last winter (dec 05-Jan 06), I had built a spreadsheet with dyno #s from this thread. I just finished updating it and added some more info from other TMS threads. Not all incompassing, but it is a handy tool for looking at:
1. Various stock dyno #s (including averages) 2. Seeing the dyno changes for a TMS member as they add more mods 3. Seeing how various mods effect the dyno #s. 4. Worksheet labeled "superchargers" has #s and sources for various mustang superchargers. 5. Click on a members' name to go the the source of the info. Note that you can filter the selections on the top line. For example, on the 1st worksheet, if you just want to see all the 4.6L, manual, stocks, on a dynojet, you just select those options. I'll also post this in another thread so that it has more visibility. |
AFBlue that's some impressive work!!! It's exactly the sort of thing I would do.
The only thing that bothers me is that some people may be posting raw numbers or STD corrected numbers instead of SAE corrected numbers (here's one example). The printout I got from my baseline run said I was making 281 hp/308 tq. :banana: I nearly jumped over the counter and kissed the guy until I realized he'd printed out uncorrected numbers. :doh: |
Yeah, I didn't religiously do it, but when I saw someone post "SAE corrected", I tried to put it in the notes column. Also checking the associated link sometimes will tell you whether it was SAE corrected.
Current dyno numbers:
Dynojet (SAE 5) 300.26 RWHP / 315.67 RWTQ Current mods: Bassani X-Pipe w/ Comp. Cats. Bassani Axle Back Mufflers LFP Twin Blade 62mm TB WMS 95mm High Velocity Intake w/ Ram Air Tray Meziere Electric Water Pump Steeda UPDs Moto Blue Gen. II 90mm Idler Pullies hags1 |
I'm impressed! That is quite a nice spreadsheet, and very handy for comparing numbers.
I'm in the top 20 for HP. Not bad for a V6. Wait until Rygen gets his DynoJet numbers, though..... I think we'll all be floored.
Originally Posted by AFBLUE
(Post 915391)
2 Attachment(s)
Guess I've never really posted here.
2006 GT manual. Steeda CAI. SCT II w/tune from Steeda.ca. JBA Axle back. 289.1hp, 285.2tq. Mustang Dyno. Nice warm day, not too hot, not too cold. |
294hp/304tq. SAE Dynojet numbers
'06 manual, C&L street intake, Evolution 93 octane tune, CMCV deletes, Steeda UDPs, Magnaflow axle backs Dave Kegel |
I got 293rwhp/313rwtq. STD DynoJet Numbers
-'07 manual, C&L Racer, Custom 93 Octane Dynotune, 3:73's(makes it read lower), Steeda CMDP's, Motoblue UDP's, Flowmaster Axlebacks |
Originally Posted by mustangfan123
(Post 927784)
-'07 manual, C&L Racer, Custom 93 Octane Dynotune, 3:73's(makes it read lower), Steeda CMDP's, Motoblue UDP's Any chance you have your corrected numbers? It's very difficult to compare uncorrected numbers because of the weather differences. They would be much lower if done when it's 80 degrees vs, say, 50. Dave |
My car was dynoed in high humidity, pretty hot weather. Is there any way you can calculate SAE numbers?
Also,I think the gears make it lower since the engine is using more hp to mantain the several hundred higher rpm's that the gears cause.:dunno: |
The dyno calculates both uncorrected and SAE corrected numbers. I only have the graph and "spreadsheet" SAE numbers, I didn't ask for the non-corrected numbers. I'm surprised you have the uncorrected nnumbers, that seems odd that your dyno guy would give you those. There's no way (as far a I know) to extrapolate one type from the other. It's based on temp, humidty, and baro pressure.
Dave |
Originally Posted by dkegel
(Post 928951)
(Post 928951)
-Scott |
New dyno #s. I haven't scanned the sheet yet.
Mustang Dyno Temp: ~90* humidity: ~60% VERY rich tune, <= 11:1 But anyway: 311 rwhp 330 rwtq Mods: C&L Racer CAI Steeda UDPs Steeda CMCV DPs ARH LT headers, catted H-pipe 93 oct Race tune from TillmanSpeed I leaned it out a couple of times b/t runs and gained 6rwhp and 7rwtq, so there some more playing w/ A/F ratio to do there. A/F was still below 12:1 |
Originally Posted by The Dark Horse
(Post 928979)
Mine did the same thing. I think they do that because you get bigger numbers (and happier customers).
There sure is. It’s the SAE J1349 JUN90 standard. There's a formula here you can work with: http://wahiduddin.net/calc/cf.htm Although, strangely, it does not include humidity. -Scott Dave |
I finally scaned the sheets. Turns out my max tq was a little higher than I originally posted above:
http://i19.photobucket.com/albums/b1...hart3May30.jpg Here was the first run. The A/F is actually a point lower than shown on these graphs, so it's mostly under 11:1 from 3500rpm on up, with a dip to almost 9:1 at then end. http://i19.photobucket.com/albums/b1...hart1May30.jpg |
