what have I done ?
Old Dec 6, 2017 | 03:55 PM
I-70 west's Avatar
what have I done ?
did a strut replacement on my 06 & the left side doesn't true up
Old Dec 6, 2017 | 07:08 PM
houtex's Avatar
Dismount, turn 180 degrees, remount. Or 90 one way or another. Point is, there should be a notch you have to face to the 'outside' of the car (to the fender), otherwise, you get this. The studs are offset to produce the correct camber.
CJ video to help ya on that:
That will fix your camber issue.
Old Dec 6, 2017 | 07:31 PM
I-70 west's Avatar
do I need to compress the spring again
or can I rotate it manually ?
Old Dec 7, 2017 | 08:54 PM
houtex's Avatar
No, the top of the mount should just freely turn about. Jack the car up, take the wheel off, compress the spring a little by jacking the control arm up, undo the four bolts up top, slowly(!) release pressure of the jack until the mount comes out of the tower, rotate the top until aligned as shown in the video, align the mount into the tower as you jack the control arm up, get it seated, bolt it in, remove jack, wheel on, lower car, done.
Of course, the 'better' way is to do it like the video sans disassembly of the strut/spring/mount assembly because of the control arm jacking being a potential of 'oops', but I've done it this way before. Just be careful about it it'll be fine.
Old Dec 11, 2017 | 08:23 AM
I-70 west's Avatar
thank you very much !
All done !
Art
Old Dec 11, 2017 | 10:56 PM
houtex's Avatar
Sweet! Glad to have helped out!
Old Dec 12, 2017 | 01:56 PM
TymeSlayer's Avatar
What's so bad about a little negative camber...
Freakazoid
Jun 1, 2011 08:03 AM
3Strikes
2007-2009 Mustang GT/CS
15
Jun 23, 2008 09:53 PM
TMSBrad
41
Mar 10, 2005 06:54 AM
HOTLAP
Jan 14, 2005 03:32 PM
BeachFord
Nov 23, 2004 07:32 AM
