Rattles database
This could either turn out to a brilliant sticky.. or fail misrably.. anyway, i think it's worth a shot.
This thread should have everyone's personal findings about rattles, their sources, locations, and remedies.
if possible, attach pictures, diagrams or illustrations.
Please keep it to the point, and keep questions off this topic (ask in a different topic, or through a PM, so original posters can edit their post and include the note to answer your query)
Door trim panel handle cover
I had this rattle in the passenger side door.
it turned out to be the door trim panel handle cover (pointed out in the attached photo)
Solution involved removing this cover (it pops off by a flathead screwdriver) and putting thick double sided tape behind it.
Make sure this plastic panel can still be removed if needed after the solution is applied (so no super glue!)
The rattle might also occure in the driver side door, due to the similar design.
Leather gearshift lever boot
This is more like Rubbing/Squeeking than a rattle, and is caused by the leather shift boot being folded and rubbing against itself especially when in 1st or 2nd gears.
To resolve:
Pull the shift lever boot and lift it up, so it's no longer latched into the console floor board.
hold the shift **** firmly and unscrew it (counter clockwise)
it might be easier to shift into 4th gear to give enough clearance for the shift boot, as it will be rotating along with the **** while you remove it.
once out.. apply the leather conditioner and wax evenly on the outside of the leather shift boot, and reverse the procedure above to install.
make sure you tighten the **** down so it won't twist while shifting.
To resolve:
Man, if your this concerned about rattles and squeeks you wouldnt want to ride in my Supra. Every little bump I go over, something in the hatch squeeks.
But it doesnt bother me *shrugs*
I have squeaky noise coming from the Emergency brake handle. I started a thread about it, but never really got a resolution to it. It appears to come from the two plastic case pieces that come together under the emergency brake's rubber grip. Holding them causes the noise to stop. Doesn't always occur on a bump, it can be heard from vibrations.
I also have a rattle coming from the A-Pillar in the drivers side, it is the piece that connects the roof with the dash. Rattle's all the time....I can push on the plastic interior trim to make it stop, but there has to be a fix. Dealer couldn't hear anything when I went in... :\
That's one of the reasons I was relieved when I found out they wouldn't be making another hatchback.... back in the day when Motor Trend's renderings indicated such.... my '88 GT was horrible for that..... and when I was driving fast with a heavy cross wind, the rear gate would agtually lift up and I could see daylight...
I have rattles in a similar place... except it's the little cover panel behind the release lever...
And besides the usual occasional rattle in the dash... I have something particularly annoying in the pillar behind the driver's seat.... I haven't delved into that one, so I don't have a solution. I'm going to go to the dealer and make them take care of it... 'cause I have other issues... such as the fuel pump, the strut popping, and the rear end vibration (ring and pinion)...
I won't say that this would ever discourage me from buying another Mustang.... like you hear people say when the first thing goes wrong.... ALL cars will have issues, simply by virtue of being mechanical .... I got plenty for my money, and these little issues can be resolved.. so, no big deal.
To resolve:
To resolve:
To resolve:
To resolve:
I actually had several rattles in my previous 06. Some fixed by me others fixed by the dealer. I don't have a car to take pics of so I will just borrow some from others, hope they don't mind.
Vibration in driver door (shown in Pic 1)
The Problem: The mid area of the door will vibrate while playing music or in cold weather.
The Fix: My dealer did this one, they removed the door pannel and put adhesive foam and reinstalled the pannel.
Various Rattles from A-pillars (shown in pic two)
The Problem: I had two persistant rattles coming from the A-pillar area (plastic parts that but up against the dash and run over the doors). one was a "tick" noise that happened over bumps, the other was the normal rattle noise most seem to complain about.
The Fix: For the tick I had my dealer do that. The dash would shift slightly in the corner of the passenger side and tap the glass, they installed adhesive foam at the contact point far in the corner. The rattles I did, I took felt (can be bought at any craft store) and cut it in to 1X1 inch squares. Put the felt in the far corners not going to far toward the middle of the windshield,
as the dash gets thiner and you will drop the felt behind the glass (very annoying to retrieve) Then used either a tooth pick or similar sturdy object to push the felt in snug. For additional noises cut the felt into thin rectangles and use the tooth pick to stuff the felt down between the seam of the A- Pillar and the top of the dash.
2 rattles to speak of. Both came around AFTER my exhaust change. The first is the little key release cover on the auto shifter. An annoying little buzz that is only there during a certain rpm range. I got a PM from a member hear telling me to try clear silicone on it but I haven't gotten around to do that yet, so I can't say for sure if that is the fix. The second is the far right ac vent. It rattles like crazy at all rpms when fully closed. Now I just leave it partly open.
