MPG Issue
Old Mar 24, 2010 | 04:23 PM
pilatti1's Avatar
MPG Issue
I have an '07 GT/CS 5 speed manual and recently my MPG has dropped from around 18+ MPG around town to about 15 - 16 MPG. Any ideas? I have about 46,000 miles with a K&N Drop in filter, synthentic oil changes every 5k miles. The only thing i can possibly think is that I have never changed the fuel filter not sure if that would do it o not.
Old Mar 25, 2010 | 05:29 AM
Beargap's Avatar
Sounds like the kind of drop I see when the oil companies have to switch to a winter formula or when using gas with ethanol.
=Vic=
Old Mar 25, 2010 | 08:18 AM
Dixie_Flatline's Avatar
I'd say the same thing about the seasonal fuel formulations... but 46k miles and still running the stock fuel filter?! Yikes, change that thing, it's pretty quick and about $25 for the Ford filter. Just my $0.02.
Old Mar 25, 2010 | 08:34 AM
karman's Avatar
Wink
I would assume that a clogged fuel filter would decrease performance, but increase gas mileage.
The filter change s/b done at 30K mi. though.
Old Mar 25, 2010 | 08:53 AM
I'm not taking any bets as to whether the old fuel filter is the MPG culprit, just that I've seen some shamefully dirty fuel filters with only 25k miles on them.
There are a lot of different factors that could contribute to gas mileage changes though. Does it still run the same now as it did before?
Old Mar 25, 2010 | 09:22 AM
Mas35NYR's Avatar
18 mpg? Wow that's great, I typically average 14 mpg but then again I can't get out of 3rd gear cause it's just so much fun!
Old Mar 25, 2010 | 09:37 AM
pilatti1's Avatar
Yeah the car runs same as day 1 just the drop in MPG. ion this tank I even tried to baby it (no high RPM shift changes) and now it is around 15mpg. I have tried Lucas fuel injector cleaner and a tank of 89 octane at the same time - as I usually run 87. I will try the fuel filter change to see if that does anything to help out. If not what else should I be looking at?
Old Mar 25, 2010 | 12:57 PM
karman's Avatar
Post
You haven't mentioned the last time you cleaned the air filter.
An air filter can clog in 1 day in dusty areas.
That can kill MPGs easily.
Old Mar 28, 2010 | 10:32 AM
Cavero's Avatar
I'm experiencing the same thing and I did change my fuel filter at 30k, and clean the air filter (also K&N) every 6 months
Old Mar 28, 2010 | 01:16 PM
Cusp's Avatar
+1 on the summer blend. I have seen my MPG change that much when running on Arizona gas vs California gas. FYI, it goes down in California.
Old Apr 5, 2010 | 12:52 PM
pilatti1's Avatar
So i changed the fuel filter (it was clogged) also cleaned the K&N and seems like I back closer to 18mpg. Amazing what a little maintence can do!!! Thanks
Road_Runner
Sep 2, 2024 04:46 PM
kponypower
Jun 17, 2020 07:17 AM
NC14GT
Sep 10, 2017 04:47 PM
09-gt/cs
Oct 15, 2015 10:03 AM
