Headlamp fogging (condesation)
Old Jun 12, 2007 | 08:50 AM
Louie's Avatar
The LH-side headlamp has lately started to show a considerable amount of condensation, especially visible a few hours after driving the car. I checked the lens and there is no apparent crack or defect in the seams. Is there an easy fix for it that I could try, before ordering a new lamp? I'm thinking about removing the bulb and blowing warm air inside the lamp with a hairdryer.
Any other suggestions? Thanks!
Old Jun 12, 2007 | 09:15 AM
Tampa07GTCS's Avatar
I had this problem in my 07' GT/CS Driver side headlamp....took it to the dealership and they replaced the whole unit!
Old Jun 12, 2007 | 11:29 AM
Louie's Avatar
Thanks, but that's not a quick fix in my case (the local Ford dealers don't carry Mustang parts... )
Anyway, I did remove the bulb and dried the inside of the lamp with a hairdryer. Now I have to wait and see if it happens again. If so, then I'll order a new headlamp myself.
Old Jun 12, 2007 | 12:23 PM
ShowGT's Avatar
I have had slight condensation at one time, but never seen it again. I know my Lightning taillights would do this from time to time and Ford said it was normal.
Old Jun 12, 2007 | 01:00 PM
Sorry not a quick fix answer....good luck!!!
Old Jun 14, 2007 | 04:53 AM
Lime GT's Avatar
I guess you could apply soapy water on the outside of the assy, then apply a little compressed air through the bulb hole, to cheak for leaks you might not be able to see along a seem.
Old Jun 14, 2007 | 12:39 PM
Tboned's Avatar
Maybe the fix is to vent it to atmosphere so the condensation has somewhere to go...
Old Jun 14, 2007 | 01:59 PM
WB05stang's Avatar
I am pretty sure the lenes have a vent hole.. Is this plugged?
Old Jun 14, 2007 | 03:07 PM
kevinb120's Avatar
Something has to keep them from fogging, even when it dries it leaves water spots on the inside-the **** OUTSIDE is hard enough to keep clear as it is
Old Jun 16, 2007 | 04:40 AM
Agleon's Avatar
I have water in my front turn signals. Going back a 2nd time to get them replaced. also have my passenger side foglight fogging up.
Raynier Leonardo
'10-14 Exterior Modifications
27
Mar 2, 2017 12:08 AM
DEPUTY62
Sep 12, 2015 11:12 AM
