Headlamp fogging (condesation)
The LH-side headlamp has lately started to show a considerable amount of condensation, especially visible a few hours after driving the car. I checked the lens and there is no apparent crack or defect in the seams. Is there an easy fix for it that I could try, before ordering a new lamp? I'm thinking about removing the bulb and blowing warm air inside the lamp with a hairdryer.
Any other suggestions? Thanks!
![Thumbsdown](https://themustangsource.com/forums/images/smilies/thumbsdown.gif)
Anyway, I did remove the bulb and dried the inside of the lamp with a hairdryer. Now I have to wait and see if it happens again. If so, then I'll order a new headlamp myself.
I guess you could apply soapy water on the outside of the assy, then apply a little compressed air through the bulb hole, to cheak for leaks you might not be able to see along a seem.
