Dashboard rattle
I have a rattle from the driver's side dashboard. I think I've localized it to the black plastic piece nearest to the windshield where the defroster vents are located.
On other cars I've owned there has been either a foam strip or black rubber wedges placed between this piece and the windshield. Could someone check and see if their GT has any foam or wedges? I think I can solve this by putting some foam in the space between the plastic and the windshield. Noise goes away when its hot and the plastic expands. The dash sure does creak with temperature changes.
Thanks.
Thanks.
Thanks.
Thanks.
Another rattle was being caused by wires rattling against the metal hinge of the glove box. I opened the glovebox completely until it was hanging down, and wrapped a small towel around this metal part to isolate it from the rattling wires. that solved that problem.
no more rattles
I have a "vibration" rattle on my passenger side...Its driving me crazy. Its behind the panel just above the glovebox. If I put pressure on the panel the rattle goes away. Dealer here I come....
![Post](https://themustangsource.com/forums/images/icons/icon1.gif)
Originally posted by E-Rock@July 13, 2005, 12:09 PM
Welcome to the rattle club. A lot of people have posted about the same problem. The service center was having trouble finding it so I pressed firmly on the dash and it hasn't made a peep in a week. I'm pretty sure it will return but for now I have my sanity back.
i had that rattle and it actually ended up not being the dash but the pillar that goes from the dash to the roof. the plastic wasnt snapped down all the way. all i did was press it into place and you could hear it snap in. yay! no more rattle.
Originally posted by 05windveilbluegt@July 13, 2005, 1:06 PM
You don't need to go to the dealer, just wedge some black foam between the dashboard and the pillar the rattle goes away. Easy 5 minute fix, and you don't ened up getting your dashboard taken apart and a slew of other rattles to follow.
Could you post a pic of exactly where you placed the foam?
I have the same rattle but haven't located the proper place to insert the foam yet (tired a couple of places, but the rattle didn't go away).
My rattle may be the glove box issue you had (the rattle goes away when the glove box is opened), so I'll try that as well.
Thanks.
[attachmentid=27452]Sorry for the picture quality. I wedged the foam in this location and this has stopped the rattle. It's not easy to see unless you are looking for it as it is black and i have the dark charcoal interior.
Originally posted by Blk'05@July 15, 2005, 7:54 AM
This is why I love this board!! Thanks 05Wind
I think I'll also try this..
If you still have a rattle try wrapping a small towel around the glovebox hinge to isolate it from wires that may be vibrating against the metal
Now the only sound i hear in the car is the motor
robjh22
9/8/15 12:31 PM
