bullitt RPM raised 250 ?
Old Feb 10, 2008 | 06:17 AM
newdy22's Avatar
Originally Posted by on d bit
the redline and actual rpm limit are two different things. the rpm limit, meaning the computer will not let you rev it beyond this predetermined number is there to protect the engine. whats the redline for? to tell one your getting close?
I thought the red line was an indication that you were getting close to the rev limiter, as stated above. However, I found that the 08 Bullitt I purchased has a the rev limit set at 6,500 rpm, exactly where the red line is. The rev limiter has kicked in each time I take it to red line; three times now. Just as I hit 6,500 rpm and start to press the clutch in I can feel the rev limiter kick in. Is there any way to move the rev limiter to 6,750 rpm so I can take the rpm up to 6,500 without have to make sure I shift at 6,499 rpm?
My 88 GT had a yellow line at 5,000 rpm and a red line at 6,000 rpm. I shifted at 5,400 rpm. Taking it any further was pointless because I could feel the power drop off. I did not have to worry about a rev limiter kicking in.
The 08 Bullitt pulls hard to 6,500 rpm. I cannot feel any power drop off when approaching red line at 6,500 rpm. I don't intend to take it over 6,500 rpm, I just want a small buffer in case I accidentally take to 100 rpm over.
I have read the GT red line is 6,250 rpm. Is the rev limiter set at 6,250 on the Mustang GT?
Old Feb 10, 2008 | 11:05 AM
In my first drive I only came close once - being new engine and all. And with all the excitement and unfamiliarity I could be mistaken. But I'm pretty positive my limiter kicked in before 6500 - like around 6400. I was only going to peg redline but I felt the sputter before I got there.
Glenn
73
Apr 26, 2016 12:22 PM
Fastnloud
Feb 15, 2016 05:21 PM
yabutt
Oct 23, 2015 01:05 PM
Gabe
Sep 7, 2015 03:30 PM
