let me know if this is a problem!
i changed my oil putting in regular oil not a synthetic blend my cqar has 175 miles on it now.i was planning to go to 1000k before my next one.should i get a oil change again and put in the synthetic blend? will regular oil harm the engine?
Originally Posted by Tiberius1701
Factory fill is 5w20 synthetic blend oil, using "regular oil" as long as it meets Ford specs will cause no issue.
i was weird my car would blow up,i was about to get another oil change.im using a fram filter with penzol.im going to change it at 1000
you guys are not gonna belive this(or maybe you will)
when i went to put on the k&n oil filter yesterday,after hearing so many bad things about fram guess what? the f ucking filter was LEAKING i couldn't belive it. the filter was very tight on but it was just leaking.i know it's a cheap filter but come on,i'm defintly gonna just stick with k&n.i get them for 9$ here on post.
Go to Wal mart and buy the Motorcraft oil 5-20 synthetic blend 5qt bottle = $9.52 Motorcraft oil filter = $3.28 (my 98 Cobra 4.6l & 06 F150 5.4l use filter #820S they should be the same).
Originally Posted by Dougxox
175 miles is overkill, I am going to wait for 500 for the first just to get the metal filings out, then 1000, then onto regular maintenance . Some people think the 500 is overkill, but as your engine breaks in there is a lot of metal floating around just want to get it out before it gets somewhere it does not belong. Also what kind of stuff is in there from the factory?
The thing that shocked me was that the car was not full at 6 quarts. Looks like it needs 6 1/2...I put in mobil 1. Probably overkill, but better safe than sorry in my book. I used the mobil 1 oil filter as well.
What comes from the factory is synthetic blend. 5w/20. That weight is hard to come by where I live.
Originally Posted by sts767
while we are talking about oil filters can someone explain to me what makes one filter better than the other? Particularly the Ford Racing one, what is so special about that?
Rando
8/25/21 11:12 AM
