What am I missing?
Old Aug 9, 2010 | 05:57 AM
dragstart's Avatar
What am I missing?
Just saw a clip on youtube of a 0-120 mph run, where there was a digital display of car speed on the tach. I did not know of this!
How do we do this??
Old Aug 9, 2010 | 06:17 AM
gkgeiger's Avatar
https://themustangsource.com/2010-mustang/486140.htm
Old Aug 9, 2010 | 09:54 AM
Stinger1982's Avatar
I am Shauny Clause
MOTM July 2010 Winner
Page not found
Old Aug 9, 2010 | 10:01 AM
2010MustangGT's Avatar
yea for some reason, links of other topics of the forum aren't working...?
But it's the engineering test mode- there's been 2-3 topics on it now. Kinda cool, as it's a look into a lot of different parameters. But it's been around since 1999...
1.) Press and hold the 'Setup' and 'Reset' buttons for the message center (located near the headlamp controls)
2.) While keeping these buttons pressed, start the vehicle.
3.) When the message center displays 'ENGINEERING TEST MODE', release the buttons. (the first test will be a gauge test, so don't freak out when the gauge needles go nuts and make weird noise)
4.) You can scroll through the different engineering readout displays and tests by pressing the Reset button.
5.) To end Engineering Test Mode, turn off the vehicle ignition, and open the door (to kill the accessory delay).
The vehicle will start up on 'regular' mode next time, unless you do the button press-and-hold again.
A few pics off my phone...
Old Aug 9, 2010 | 02:54 PM
dragstart's Avatar
Tried it, it was fun. Bored with it now.
Next !
Old Aug 9, 2010 | 10:48 PM
I am Shauny Clause
I tried this on my Boss's 2011 GT-500 today and it didnt work (the car was low on gas so the low fuel was displayed in the DIY center) think the low fuel caused my issue? Isat there on the buttons for 45+ seconds
I get my car back from Livernois (news on that tommorow ) and will try it on my GT.......
Old Jan 28, 2011 | 01:23 PM
orange3.9stang's Avatar
2010+ Mustang Engineering Test Mode
YES ... the LOW FUEL warning will not let you get into "Eng Test Mode". I tried it yesterday 1st with less than 50 to E and it did not work, then went and got gas and then it worked ... pretty cool !!
Here's all the info it displays, in parenthesis are the values displayed on my car ...
1. GAUGE TEST (gauge needles go nuts)
2. All LCD’s lit (display test ??)
3. TELLTALE TEST … all warning lamps in cluster lit
4. PART NUMBER … (BR33 - EE ... cluster P/N ??)
5. ROM LEVEL … ($0401)
6. NVH ROM LEVEL … ($0401)
7. EE PROM LEVEL … ($01)
8. MANUFACTURE DATE … ($4D98)
9. B&A CONFIG BYTE 1 … ($E3)
10. B&A CONFIG BYTE 2 … ($98)
11. B&A CONFIG BYTE 3 … ($EF)
12. B&A CONFIG BYTE 4 … ($61)
13. B&A CONFIG BYTE 5 … ($FO)
14. MANUF CONFIG BYTE 1 … ($90)
15. CONTINUOUS DTC … ($90D7-51)
16. VEHICLE SPEED … ___ MPH
17. VEHICLE SPEED … ___ KPH
18. SPEEDOMETER DC … ___ (133)
19. TACHOMETER … ____ RPM (650+/-)
20. TACHOMETER DC … ____ (308+/-)
21. FUEL1 LEVEL ___ INSTANT
22. FUEL2 LEVEL ___ INSTANT
23. FUEL1 LEVEL% STATUS … (240)
24. FUEL2 LEVEL% STATUS … (000)
25. FUEL CMB LEVEL% STATUS … (122)
26. FUEL GAUGE DC … ___ (668)
27. INSTANT DTE … ___ MILES
28. FUEL1 ON/OF/SZ … (131/255/126)
29. FUEL2 ON/OF/SZ … (600/255/000)
30. F1$S ON/OFF/SZ … (015/000/050)
31. F2#S on/OFF/SZ … (015/000/050)
32. FUEL LEVEL INIT REF … ($0583)
33. COOLANT TEMP … ___ C (94)
34. COOLANT TEMP DC … ___ (630)
35. FAIL SAFE COOL MODE … (00)
36. ODOMETER … ____ COUNTS
37. TRIP ODOMETER A … ____ MI
38. TRIP ODOMETER B … ____ MI
39. BATTERY … ___ VOLTS (14.2)
40. BATTERY A/D COUNTS … ___ (690+/-)
41. RUN/START SENSE … (H)
42. DIMMING LITVAL … (0)
43. DIMMING DIMVAL … (0)
44. DIMMING STEP … (22)
45. DOOR AJAR STATUS … (00)
46. GEM INFO STATUS … (28)
47. ABS INFO STATUS … (00)
48. PCM INFO STATUS … ____
49. MIC SWITCH … ____ A/D CNTS
50. OPS RA/D … ____
51. LAST CHIME SOUNDED … (17)
52. A/D PORT 2 … ____ (varies)
53. A/D PORT 3 … ____ (varies)
54. A/D PORT 4 … ____ (varies)
55. A/D PORT 5 … ____ (varies)
56. A/D PORT 6 … ____ (varies)
57. A/D PORT 7 … ____ (varies)
58. A/D PORT 8 … ____ (varies)
59. A/D PORT 9 … ____ (varies)
60. DIGITAL INPUTS PORT A … (3F)
61. DIGITAL INPUTS PORT B … (FF)
62. DIGITAL INPUTS PORT C … (IF)
63. DIGITAL INPUTS HET1 … (00001401)
Doug
Old Jan 28, 2011 | 01:39 PM
07S197's Avatar
Swamp Donkey Man Cans
Anyone ever try this in an 05-09?
Old Jan 28, 2011 | 02:00 PM
Mustang-4.6's Avatar
Thx for the info. I am going to try this after work.
Old Jan 28, 2011 | 09:25 PM
SD CALSPCL's Avatar
That is something I have missed on this car that my '09 VW CC had. The digital display for speed is nice when in high enforcement areas. Much easier to read then trying to look at the speedo. Thanks for posting.
kponypower
Jun 17, 2020 07:17 AM
FromZto5
75
Oct 5, 2015 02:27 PM
Sep 10, 2015 08:31 AM
dakotawolfe
Aug 26, 2015 04:01 PM
DarrenGT
Aug 19, 2015 08:22 AM
