Tapping/Clicking Engine Noise On Mine, Too
I also noticed a clicking noise from my engine right after my third oil change around 15K miles. The noise is exactly the same as what blackboy31 and HizliBullet posted. I have GT Track Pack and have been using Motorcraft 5W-50 Full Synthetic. My situation is almost identical to hatchttu up to a point. The dealership took two weeks to investigate, searched for the noise and eventually determined it was coming from the bottom of the engine. They took off the oil pan and did find metal shavings. They took off the caps and inspected the bearings and found scoring on the outside on two of the bearings. At first they were going to replace the two bearings, but upon further investigation, found metal chunks cut out of a rod. They said that not all the shavings in the oil pan were magnetic, so something aluminum was also damaged. I'm just a car enthusiast, not that mechanically inclined, so I don't completely understand all of this. Anyway, Ford hot line blah, blah, blah, and I'm getting a new long block. I had a botched oil change back at 5K miles (read the post), so while this whole thing is a huge clusterf@#k, I'm hoping to start fresh in March when my car is put back together again. I really love this car, but a new engine at 15K miles does not bode well. I thought the Coyotes were bulletproof. Anyone have any thoughts or advice?
You should know by now that the Coyote is not bullet proof. It has had its share of issues. (But most are worked out now.)
But hey - you get to break in a new engine.
I'm curious if the filings started from a failed roller finger like some have. Sends filings throughout the engine via the oil pump.
I have no mods to my car. The botched oil change is detailed in an earlier post on this forum. At my second oil change at 10K miles, the dealership put 6 quarts of synthetic blend instead of 8 quarts of full synthetic. I didn't notice this until 2 or 3K miles later when I checked my oil and saw it was 2 quarts down. I'll never know for sure if that caused any of the damage, but I'm getting a new engine so that will at least be behind me.
What kind of noise exactly? I have a very light ticking as the engine is warming up. Goes away once the engine is warmed up.
I have a boss, so I figure its just the forged aluminum pistons. Those are noisy until the warm and expand.
Deysha
the stealer ships don't know jack my very first service Suburban Motors here in Victoria where I bought the car tried to tell me I didn't have a cabin air filter 😨 I had to walk the tool out side to show them in fact that I did. fail ford fail
Hi Tek - it might simply be piston slap. My Boss does it as well since about 5k miles and goes away once warmed up. I might also be that stretchy belt TSB. I just turned 16k and have been FI for 2k miles now with no issues other than a lots of tires
Here's the TSB:
http://cdn.lrsstatic.com/downloads/t...sb12-08-14.pdf
Basically, some cars are making a noise and the fix is to go to a tensioned belt for the AC instead of the original set up without a tensioner.
The part I do not understand is why they have to reload the PCM.
Dealer called me back, there is a TSB for the boss 302 for piston slap during warm up with high flow CNC heads. Normal operation.
Everything checked out good.
No charge. Did get compliments from everyone at the dealer on my car and how it sounds!
Deysha
Evil_Capri
9/11/15 08:39 AM
