Tape stripe delete on MCA package
Hi, on the Ford site I was building a V6 with the MCA package but I don't like the hockey stripe so I added the tape stripe delete option. That had the side effect of removing the MCA grill and replacing it with the standard one. I tried the same with the Pony Package and the stripe was removed and its grill left in tact. Does anyone know if the tape stripe delete option on the MCA really does revert back to the standard grill or if this is just a bug in the site? I REALLY love the look of the MCA grill... I REALLY hate the hockey stripe.
tom
tom
The first car delivered to someone on this site(actually his mother) was a MCA package and they did delete the stripe apparently.
Really though it is nothing to worry about even if they don't delete it, it will peel off pretty easy with just a little heat applied with a hair dryer.
If you're basing that on the picture the website generates of the car as you build it, be careful. My experience while fiddling around building the 2010s was that it was more better to go back to the very beginning and start over because some of the changes didn't show in the picture after a 'delete'.
Yes, the B&P web page is still screwed up so take nothing from it as gospel.
*EDIT: Of course, reading the entire thread before replying helps to avoid redundant redundancy.
Per the order guide, you can get 47A OTT Stripes on any V6 but with either 201A or 202A (Pony or MCA) you must also select 46D tape stripe delete. 943 Hood & Side Stripes also appear to be available on all V6 trims and req's 46D also.
Question that we don't know "for sure" is does 46D also eliminate the MCA blackout treatment on the rear ??
Doug
Doug
I'll post pictures and info once mine arrives. According to Ford's customer service line, it's currently on the train en route to my dealer. My 5/6 ETA (or earlier) to DFW is looking promising at this point.
Awesome! Your avatar is pretty much what I want except the color. Can't wait for the pics.
Doug
Doug
Time for a bump. Evolution Performance has received their 2011 MCA Mustang in Sterling Gray. They ordered it with the tape stripe delete which deleted the hockey stick stripes. The front billet grille is still in tact (which we all expected) but I'm still waiting for a response confirming that the rear is still blacked out.
Cobiecane
Oct 23, 2015 08:44 AM
