Street Tires
Street Tires
Is there any advantage going with a 275 over a 255 for every day
street use. I will be buying a set of Pilot SS.
Originally Posted by 5.M0NSTER
It will be harder to break the 275s loose in 2nd gear, or even in 1st over 4000 rpm if you don't jump on the throttle.
Going from a 265/305 staggered MPSS setup to 255/275 Cooper RS3s, I say save your money and go with the Coopers. I'm that impressed with these cheap tires!
False. I broke the MPSS 305s loose like no other. My Cooper RS3s actually seem to hook a little better, all other things equal, even though they're 275s.
If you keep the same tire model and go wider they will be more difficult to break. That's just physics. Same load on the wheel and more surface area with the wider tire = more traction.
Received 1,547 Likes
EDIT: oops, now I see that you went with the 255 PSS tires . . . those are supposed to be awesome tires, interested to hear how they work out for you.
So Far the Pilot SS is a major improvement over the GY Supercar tires. When it rains on Sunday I'll see how good they are in a hydroplaning environment.
PonyMuscletang13
26
4/4/16 08:08 PM
Evil_Capri
11/16/15 01:19 PM
