Street Tires
Old Dec 5, 2015 | 09:00 PM
TheReaper's Avatar
Street Tires
Is there any advantage going with a 275 over a 255 for every day
street use. I will be buying a set of Pilot SS.
Old Dec 5, 2015 | 09:03 PM
ElkGroveFordGuy's Avatar
It makes a real difference in traction!
Old Dec 5, 2015 | 09:13 PM
TheReaper's Avatar
There's only a half inch difference in the tread with.
Old Dec 5, 2015 | 09:18 PM
It's noticeable, I went from the 255 to 275 same p zeros and yes noticeable difference
Old Dec 6, 2015 | 09:05 AM
5.M0NSTER's Avatar
It will be harder to break the 275s loose in 2nd gear, or even in 1st over 4000 rpm if you don't jump on the throttle.
Old Dec 6, 2015 | 11:47 AM
False. I broke the MPSS 305s loose like no other. My Cooper RS3s actually seem to hook a little better, all other things equal, even though they're 275s.
Going from a 265/305 staggered MPSS setup to 255/275 Cooper RS3s, I say save your money and go with the Coopers. I'm that impressed with these cheap tires!
Old Dec 6, 2015 | 12:36 PM
TheReaper's Avatar
I looked hard at the Cooper's, if the Pilots don't work out I might go cheap
the next time.
Old Dec 6, 2015 | 04:44 PM
5.M0NSTER's Avatar
If you keep the same tire model and go wider they will be more difficult to break. That's just physics. Same load on the wheel and more surface area with the wider tire = more traction.
Old Dec 6, 2015 | 06:26 PM
TheReaper's Avatar
I went with the 255 pilot ss, they should be better than the GY Supercar tires I have now.
Old Dec 7, 2015 | 09:49 AM
And what I'm saying is, in my experience, depending on temperature, the RS3s have just as much if not more traction than the wider PSS that I had. Now put them on a track with the PSS in their optimal heat range, and obviously the PSS will (most likely) have more grip.
Old Dec 9, 2015 | 06:02 AM
Bert's Avatar
Are you currently exceeding the traction of the tires you have now? Probably not, in normal street use . . . if that is the case, then more extra traction that you don't use or need isn't really going to make any difference.
EDIT: oops, now I see that you went with the 255 PSS tires . . . those are supposed to be awesome tires, interested to hear how they work out for you.
Old Dec 11, 2015 | 08:59 PM
TheReaper's Avatar
So Far the Pilot SS is a major improvement over the GY Supercar tires. When it rains on Sunday I'll see how good they are in a hydroplaning environment.
Old Dec 14, 2015 | 09:37 AM
ford20's Avatar
+1 to that! The MPSS are not a straight line performance tire. I could break mine loose as well but during the turns it would just stick and plant and hold. Great track day tire, not so much for drag racing though lol.
Old Dec 14, 2015 | 06:20 PM
TheReaper's Avatar
The PSS has much more grip off the line than the GY SuperCar and the Conti DW. I am very impressed so far.
PonyMuscletang13
26
Apr 4, 2016 08:08 PM
SD CALSPCL
Jan 22, 2016 08:45 AM
Evil_Capri
Nov 16, 2015 01:19 PM
Bruthnlaw
Nov 13, 2015 08:37 PM
