Is Rev matching healthy for 5.0 stang clutch?
Originally Posted by Sky Hye
I do it as much as possible. Sometimes it's tricky with pointy dress shoes. Especially because the pedals in my 12 were the aluminum ones. Hardly an grip on those
http://www.srpracing.com/pd-mustang-...ing-pedals.cfm
They look pretty nice.
So what is the trick to doing a well executed rev-matched downshift in these cars with the throttle lag? I tried it a few times and got frustrated quickly and quit. I usually just let the clutch out slowly to avoid the jerk, I know that does put some wear on the clutch.
To you other guys who can't do it either: don't feel too bad, I am a drummer and I can't do it!
Sometimes it will seem like you've given too muh but the adaptive throttle helps you out. I hardly, if ever over rev. But it's fairly quick for an ec throttle. But I miss the cable throttle.
Originally Posted by MRGTX
Any time you slip the clutch like that, youre shortening its life...but there are worse habits out there.
If you sit on the clutch for 3 seconds during every shift, you'll shorten its life. You're not going to shorten its life by shifting normally, and doing that requires that you slip it a little bit. Otherwise, you jerk the hell out of the car and the transmission. You're not going to kill your clutch in six months or five years by making smooth shifts.
thats what I thought, ok some slippage is good then
Go back and read this thread...I think you'll find that this basic part of operating a manual transmission has been well covered.
When you properly rev match... you'll neither slip the clutch nor "jerk" the transmission.
Just give it a try...you'll eventually get good at it.
I have been practicing heel-toe for the past two days...not ready for the track yet but I'm already a hell of a lot better at it than I was last time I tried.
Originally Posted by devildog1679
Sullivan Racing Profucts sell some nice pedals for our car. The clutch and brake pedals ate a little wider. They have two different gas pedals, one is slightly wider on the left than the stocker and the other is even wider. The smaller of the two is what went with. With theses pedals I can simply roll my foot over to the gas.
