Question for those of you with lowered cars.
Old Jul 12, 2011 | 03:05 PM
alcarames's Avatar
I'm curious how many of you have camber plates vs those without who just did an alignment with no plates, and how your tires are holding up?
Old Jul 12, 2011 | 03:54 PM
Siber Express's Avatar
I ran without anything but a toe check and wore the insides of my front tires pretty bad after about 2000 miles, I have camber bolts now and the alignment is fine with those. BTW that is with .8 inch of drop on the front.
Old Jul 12, 2011 | 03:57 PM
JimmyM's Avatar
I have 1" drop in front and 2" in rear.
Camber still within specs
Only panhard bar
Old Jul 12, 2011 | 05:20 PM
11SHELBYGT500's Avatar
Only panhard bar
Wouldn't that make the front higher than the rear?
Old Jul 12, 2011 | 07:51 PM
alcarames's Avatar
Many of these springs are lower in the rear, although usually not by much. Good info here.
Old Jul 13, 2011 | 10:45 AM
JimmyM's Avatar
Nope. The Mustang's rear is higher by over an inch.. which is supposed to give off a "forward motion" appearance, which I personally don't like. The one inch difference levels it *almost*. Most other springs are lower in the rear by maybe 1/4th of an inch, which still leaves you with that nose heavy look.
Old Jul 13, 2011 | 09:21 PM
No offense to the way you like it but to me it looks like the butt is lower even if it's not. I would also think that with you or any passengers and/or stuff in the trunk, that it's butt will most certainly be lower.
robjh22
'10-14 Exterior Modifications
Oct 9, 2015 02:49 PM
devildog1679
'10-14 Interior and Audio
Sep 14, 2015 02:17 PM
robjh22
Sep 8, 2015 12:31 PM
