iphone 4 and sync?
Bear Eats King...
Bear ****s Bone
Bear ****s Bone
Originally Posted by NJCO
the iphone is not "discovering" sync
Sorry, he got in the driver's seat & did his thing. Sorry, my memories not too good so I don't even pay attention now. Next I knew, he said it's fixed. Do think he only used buttons on steering wheel?
It used to be every say 5th time I got in car I had to go into settings & turn back on BlueTooth setting. Just stopped turning itself off, as much. Now maybe every 12th time now? Only works if I go into settings & turn off BT, then turn back on, then tap connect it. Then BT logo appears on my radio.
Bear Eats King...
Bear ****s Bone
Bear ****s Bone
I do know on several models they released a sync update. You might check with your local dealer to see if an update is out for your vehicle. There were several bug fixes in the update.
Ford In-Vehicle Technology Rep
I'm glad you were able to figure it out because the iPhone 4 will definitely pair with SYNC! The iPhone is always "discoverable" so there's no setting that needs to be changed during the pairing process.
eliyarbrough -
You're correct, the text messaging feature is not compatible with the iPhone at this time.
As far as updates go, the latest software versions are as follow:
2010 - 3.1
2011 - 3.2.2
2012- 4.0.2 b
Note: your build date can effect which software version you have regardless of the model year.
If anyone has any questions feel free to PM me.
~Jaclyn
eliyarbrough -
2010 - 3.1
2011 - 3.2.2
2012- 4.0.2 b
~Jaclyn
