If dealer installs 3.73s, does ECU need reprogramming?
Old Aug 18, 2010 | 04:03 PM
jimb05's Avatar
If the dealer installs 3.73s, does the car need to be reprogrammed to correct the speedo or to readjust the traction control settings etc?
Thanks for your time and advice...
Old Aug 18, 2010 | 04:22 PM
Adam's Avatar
Yes.
Old Aug 18, 2010 | 04:23 PM
chrisheltra's Avatar
^^^ +1
Old Aug 18, 2010 | 04:30 PM
Ltngdrvr's Avatar
FRPP also sells a speedo recal box, but if the dealer is going to do the install they should be able to flash the PCM for the gear.
Old Aug 19, 2010 | 06:00 AM
csledd's Avatar
What I did in my old stang was the mods that would benefit from a tune first (like a CAI on the 5.0s) and got the tune as well. Then I added the gears and emailed my tuner and he sent me my tune with the gears adjusted and I just put it on with the tuner.
Old Aug 19, 2010 | 09:56 AM
InsidiousGT's Avatar
+1, I did same.
Get a CAI + tune first. Then do gears when you have the money and you'll be able to adjust it yourself with your tuner.
Old Aug 19, 2010 | 08:46 PM
jimb05's Avatar
I want to get the gears now so they will be covered under warranty vs me having an aftermarket shop install the ring/pinion.
CAI and tune may come later.
I'll be sure to post to let you all know how it goes.
Jul 8, 2016 08:53 AM
ustabawannab
May 3, 2016 07:54 AM
SMOKE46
Sep 6, 2015 09:40 PM
unnoticedtrails
V6 Performance Mods
20
Aug 18, 2015 03:11 PM
VGMStudios
Aug 6, 2015 07:57 AM
