Heres whats going to break on your 5.0
Old 12/3/13, 04:19 PM
Received 1,749 Likes on 1,240 Posts
Originally Posted by miner999r
I'm happy to have my 13 GT trackpack. I'm not surprised or alarmed. The only thing I need to fix on mine is the wheel hop and it seems a pretty mild suspension mod to deal with that.
The track pack does nothing for your internals if you are pushing a lot of power to your engine.
Old 12/4/13, 03:07 PM
Roller13's Avatar
I am sticking with my Coyote! Thanks for the info.
Old 12/4/13, 07:42 PM
wentw1tj's Avatar
Can someone please tell me if these issues are fixed in the 13 14's GT 5.0L. I have read that the 11 and 12's have weaker engine parts in them? Any help would be great. Thanks to all
Old 1/1/14, 12:17 AM
Gogoggansgo's Avatar
Yes u can sleep fine cylinder number eight is a distant memory as the updated pistons cope better with heat dissipation. The clutch issues have been solved.
Old 1/1/14, 12:23 AM
The '13 cars did not have piston squirters, tune slightly revised, pistons are coated, head bolts are different, front clips rear taillights and interior is different, most '13 I have seen manual make around 390 rwhp 11-12 make 370-380. Handful of differences but essentially the same car
Old 1/1/14, 08:29 AM
Tron84's Avatar
Originally Posted by Clevor
Are the cranks in the Coyote engine induction hardened or forged? The article says forged. I thought they were the former, at least in 2011. Did Ford make a change, and if so, when?
They are forged, they say the stock crank is good for 1500 hp. The boss uses the same crank, different balance.
Old 1/1/14, 09:40 AM
Thamac15's Avatar
What parts did you hear were weaker and where'd you hear that? I'd like to read or research it.
Old 1/2/14, 10:31 AM
Krohn's Avatar
Good read but I am curious... does any of this apply to the 2012 Boss 302?
Old 1/2/14, 03:51 PM
Yes there was a few early 12 boss failures due to warped heads from extended track use. And issues with oil consumption from the rings not seating, and piston slap have had a few engines replaced. But forged pistons are loud when cold. all the problems where fixed with the 13s expect for the piston slap.
Old 1/2/14, 03:53 PM
Size:  178.9 KB 12 vs 13 gt pistons
Old 1/2/14, 04:38 PM
dmichaels's Avatar
I haven't seen stock 2013/2014's making 390 whp... the Boss does, not GT's. My GT TP was 376 whp on a dynojet, which seems to be roughly average, maybe a little on the higher side for stock.
I could be wrong, but all the dyno's I've seen of 2011-2014 are mid 360's to mid 370's
Old 1/2/14, 04:44 PM
I have mustang mag and brenspeed dyno have seen it in the range of 380-390whp but once again ive seen boss 302s dyno the same as a gt. But dynos are not good for setting a standard anyways. But the 13-14s are more consistent than the 11-12s
Old 5/1/14, 05:15 PM
Well it's does show that the srt8s are not the most reliable bunch
kponypower
6/17/20 07:17 AM
Gill5oh
10/6/17 10:50 PM
Infamous_blackbeard
10/8/15 10:45 PM
Christopher Fox Wallace
9/26/15 11:55 AM
Quick Reply: Heres whats going to break on your 5.0
