Frost on the inner side of windshield
During this bitter cold winter, I find that in some cold morning and evening there is frost on the inner side of windshield, sometimes inner side of door windows as well.
Since this is my first vehicle with frame-less doors, I am not sure if it is common for this kind of vehicle. Is there anyone having same experience as I? Any solution?
For now, I just keep a bottle of De-ice in my stang and use it as needed. But the inner side frost is still annoying.
It has to do with the air outside and the air inside your car.
There may be moisture in the car before shutting it off. Try running the A/C a little before you park it. Or,...if you garage it, crack the window, just a bit to let in some outside air.
Good luck!
Good luck!
1 Post
make sure that you do not have the heat vents set to defrost (windshield) before you shut the car off. you want to make sure the vents are set to floor or dash, never to defrost/windshield.
Also, remember most repairs done at a Ford Dealer come with a 24 months/unlimited miles warranty. You can schedule an appointment online here.
Deysha
When you get a chance, clean the inside of your windshield and windows. After a while, moisture starts collecting on your windshield.
At first, your windshield and windows will start fogging up quicker. Then, if enough moisture builds up and temperature get low enough, it will freeze!
