Droid issue with Sync
Old Apr 28, 2015 | 06:28 AM
SpeedCostsMoney's Avatar
Question Droid issue with Sync
I got a issue with my new Droid Turbo. The phone connects fine to Ford Sync on my 2010 GT and stays connected. However, no matter what music app I use the steering and radio controls to skip a track only sometime work. I have to unlock the phone and select to app to get it to working again. Anyone had this issue before?
Old Apr 28, 2015 | 08:29 PM
FordIVTteam's Avatar
Ford In-Vehicle Technology Rep
Hello SpeedCostsMoney,
Have you already checked to make sure you're running the latest software? Log in at: Owner.Ford.com to make sure.
Also, check out these awesome troubleshooting tips: http://owner.ford.com/how-tos/sync-t...html?sync=sync
Let me know how everything goes!
Kim
Old May 1, 2015 | 08:19 AM
I can not get the software to update. I might have to take over to the dealer.
Old May 1, 2015 | 08:20 AM
Coyote5-0's Avatar
ohhh wow, this makes me real hesitant to make the switch to Android
Old May 1, 2015 | 08:24 AM
SpectreH's Avatar
His is not the droid his car is looking for.
Old May 1, 2015 | 08:47 AM
What's going on when you try to install the update?
Rebecca
Old May 1, 2015 | 11:03 AM
It says that the install file has not been found on the thumb drive. I checked several times and the file is in the root directory.
I am worried since I just got this Motorola Turbo and it has left the return period with Verizon. I wish this issued happened day one so I could have taken the phone back.
I did not have this issue with my I-phone 5.
Old May 1, 2015 | 12:06 PM
When you download the update, make sure you're downloading it to your desktop, then unzip the files and put them on your flash drive. You should have three files on your USB: SyncMyRide (folder), autoinstall.lst, and install.lst. Is that what you're showing?
Rebecca
Old May 1, 2015 | 12:10 PM
TheReaper's Avatar
Disconnect the car battery for 10 minutes and reload your phone info after you reconnect the battery.
Old May 1, 2015 | 12:21 PM
I will try that.
Old May 3, 2015 | 12:29 PM
TheReaper's Avatar
Did it work ?
Old May 4, 2015 | 10:44 AM
No...I called their tech support. Come to find out it was a bluetooth setting. It was set to time out after 2 min. I changed the setting to never time out and it works fine now!
Old May 4, 2015 | 11:28 AM
I'm glad you were able to get it taken care of, SpeedCostsMoney! Thanks for reporting back.
Kim
Old May 4, 2015 | 07:19 PM
I hate to say it but the issue came back up again. I called and had Verizon tech support walk me through disabling some of the Motorola Moto settings. It seems to be working now but I need to test it for a couple of days.
Road_Runner
Sep 2, 2024 04:46 PM
kponypower
Jun 17, 2020 07:17 AM
yabutt
Oct 23, 2015 01:05 PM
09-gt/cs
Oct 15, 2015 10:03 AM
