Coolant temp.
Old Oct 19, 2012 | 07:04 PM
TommyV's Avatar
Coolant temp.
I'm not sure why Ford didn't include the coolant temp in the Track Apps, but I will be getting an OBD Bluetooth reader soon.
In the meantime, my dash temp gauge usually reads just below the middle of hot and cold. Does anyone know what that temp. is? (approx)
Old Oct 20, 2012 | 02:15 AM
Big Poppa's Avatar
If you really want to know, take a thermometer reading yourself. Get her good and hot, stick it in and be careful not to burn yourself opening it up.
Old Oct 21, 2012 | 01:41 AM
TommyV's Avatar
Gotta love quality responses. I guess I'll wait for the reader.
Old Oct 21, 2012 | 02:03 AM
Rather B.Blown's Avatar
Like Father...
I ♥ Sausage
Unless you're sitting and idling in Death Valley in the middle of summer for an hour, or you're running it on a track at WOT in 100 degree temps for 20 laps, I don't think you have to worry about the temp unless it blows a hose and dumps all of the coolant out.
Old Oct 21, 2012 | 05:45 PM
Bucko's Avatar
Can't answer the OP's actual question, but I've seen an aluminum adaptor that is attached inline with the upper radiator hose that has a threaded hole that fits a sensor for most temp guages. Then you'd have a true temp guage. Buy the guage holder that fits in the AC vent made by Roush (vent is still functional).
Old Oct 21, 2012 | 06:20 PM
TommyV's Avatar
I didn't say I was worried about it, I just want to know what it is.
Old Oct 21, 2012 | 06:38 PM
db2797's Avatar
It is probably around 190-195. That's what my 3.7 engine runs at normally. I'd say the 5.0 is probably around the same.
Old Oct 21, 2012 | 06:50 PM
TommyV's Avatar
Thanks!
Old Oct 21, 2012 | 09:08 PM
blk12vert's Avatar
My 5.0 runs between 190-195 as well.
Old Oct 22, 2012 | 05:45 AM
Bucko's Avatar
Take all the guess work out by adding this to your radiator hose: (has the ground screw for sensor too). Now just add a gauge pod or gauge holder in the left AC vent from Roush, and no more guess work on what the temp is.
Old Oct 22, 2012 | 06:14 AM
Overboost's Avatar
I believe the engineering menu for the message center shows coolant temp. I forget which two buttons you hold to access it (info & reset or middle & reset)
Old Oct 22, 2012 | 09:50 AM
JoesCat's Avatar
Hmm, where have I heard that before?
Old Oct 22, 2012 | 10:25 AM
Bucko's Avatar
From mom?
Old Oct 22, 2012 | 06:56 PM
jsimmons's Avatar
Wow,that's pretty famn dancer...
Old Oct 23, 2012 | 04:50 AM
Bucko's Avatar
Build it; they will come (or buy in this case).
unnoticedtrails
Jul 17, 2017 11:10 AM
Bullitt 3309
Aug 2, 2015 10:20 PM
NC14GT
Aug 2, 2015 07:27 AM
goocher625
1994-2004 V-8
Jul 15, 2015 08:08 AM
