Boss 302 ate 4 quarts of oil
Old Jun 3, 2014 | 01:44 PM
  #41
JoeMidnight's Avatar
Meh - this thread isn't going anywhere
Old Jun 3, 2014 | 06:57 PM
  #42
ace72ace's Avatar
Where um, were you expecting it to go?
Old Jun 3, 2014 | 10:32 PM
  #43
ScottV's Avatar
Originally Posted by aircare84
The oil life minder does have a calendar time limit on it as well, mine goes off every 12 months, as I usually don't hit the mileage limit.
I checked my level and it's about half way between full and empty so about 1/4 quart low at about 2,000miles on the original oil. That's not too bad especially seeing how much oil collects in the oil collector I put in.
Scott
Old Jun 24, 2014 | 07:25 AM
  #44
Krohn's Avatar
Just got the Boss back from the dealer... Ford Engineering specs that, "since these cars are made to be driven hard and most likely are driven hard, 1-qt every thousand miles is normal."
I guess I just have to check it. (btw, I baby it. It spends 90% of its time in stop and go traffic.)
Old Jun 24, 2014 | 11:25 AM
  #45
That sucks, but at least you now know why!
The last time I've babied my car, i ended up having nothing but problems with it, resulting in getting rid of it I intend on driving this car every which way! except into a wall or something
Old Jun 24, 2014 | 01:30 PM
  #46
TheReaper's Avatar
If you drive it hard it will use less oil.
Old Jun 24, 2014 | 02:18 PM
  #47
Shame on you! You're killing that great engine.
Dennis' (denlem) GT was using a lot of oil too. Dealer had no real solution. Finally Dennis went on vacation where it was a several hour freeway drive. Engine finally got to run. His oil consumption issue went away.
https://themustangsource.com/f804/5-...0/#post6700594
Old Jun 24, 2014 | 08:45 PM
  #48
Yep mine isn't using any!
Old Jun 25, 2014 | 03:26 PM
  #49
Krohn's Avatar
good read... I wonder If I need to run it more...
Oddly enough, I checked it a while back, mid oil change and no usage (that was noticeable). After my 4 drive was when I noticed it. I'm sure that was just coincidence. I'm going to check it more often either way.
Old Jun 25, 2014 | 04:49 PM
  #50
SeaFoam's Avatar
Almost to 3,000 miles - still dead center on the dipstick.
I don't beat on it, but if there's a Camaro or Challenger around, I make sure they know they drive ***** mobiles.
I guess it should also be noted that my drive to work is an hour - all highway, so there's not much stop/go.
exgto
2012-2013 BOSS 302
Oct 7, 2015 01:47 PM
southern stang
Sep 26, 2015 04:19 PM
Jailbirdwatcher
Sep 25, 2015 06:39 AM
