About to lower the '13 GT
Old Dec 10, 2013 | 06:51 PM
Homelandpatriot's Avatar
I am about to pull the trigger on lowering my 2013 Mustang GT. It is a brembo car.
My list at the moment consists of
Eibach pro-bamper shocks and strucks
Eibach sportline springs for that little extra drop
Maximum Motorsport caster/camber plates
Steeda adjustable panhard bar
Will I need anything else to make this work effectively and safely right away? I will upgrade control arms down the line but from what I've read these items listed are needed to do a proper lowering job. I could just get the springs and let it rip, but I won't my car to have a performance upgrade, not just be lower and drive for a little bit before I start seeing problems.
Down the line I will also be changing to a 20" rear wheel, maybe 20" up front maybe 19", haven't decided. But at the moment I am thinking about the TSW 20x8.5 with a 20x10 with 295's on the rear. Any problems I may run into with this drop and set up. The other option I am considering is the 19x11 with 305's in the rear on a Forgestar F14
Old Dec 10, 2013 | 08:12 PM
Brandon302's Avatar
That all should work for you. Your LCA's will most likely be pointing a little up towards the axle so you might get a little more wheel hop then usual. I would also look into either the FRPP bump stops or better yet Maximum has some that are supposed to be shorter to allow for full shock travel and still stop the metal on metal that occurs from bottoming out.
Old Dec 10, 2013 | 11:20 PM
Mr. V's Avatar
Originally Posted by Homelandpatriot
I am about to pull the trigger on lowering my 2013 Mustang GT. It is a brembo car. My list at the moment consists of Eibach pro-bamper shocks and strucks Eibach sportline springs for that little extra drop Maximum Motorsport caster/camber plates Steeda adjustable panhard bar Will I need anything else to make this work effectively and safely right away? I will upgrade control arms down the line but from what I've read these items listed are needed to do a proper lowering job. I could just get the springs and let it rip, but I won't my car to have a performance upgrade, not just be lower and drive for a little bit before I start seeing problems. Down the line I will also be changing to a 20" rear wheel, maybe 20" up front maybe 19", haven't decided. But at the moment I am thinking about the TSW 20x8.5 with a 20x10 with 295's on the rear. Any problems I may run into with this drop and set up. The other option I am considering is the 19x11 with 305's in the rear on a Forgestar F14
Your shopping list looks good. You may want to consider different shocks/struts. When I was researching my suspension, eibach shocks and struts seemed to be average at best. I think the koni strt might be a better shock and not be much more. I'd try talking to Jay at Hypermotive. They give excellent advice and service.
Old Dec 11, 2013 | 06:58 PM
tj@steeda's Avatar
Or you can look no further than Steeda to pair with that panhard bar
http://www.steeda.com/store/steeda-p...s-555-8405-11/
What are your ultimate goals for your car DD or are you going to track it?
Best Regards,
TJ
Old Dec 11, 2013 | 09:03 PM
06blackvertstang's Avatar
Post pictures when this happens. I love sportline cars with fat tires in the rear
Old Dec 12, 2013 | 04:30 AM
Nope no issues. Almost got those same TSWs. Am/will be running 305s in rear.
Old Dec 12, 2013 | 09:06 AM
I'll keep ya'll updated on this, and definitely with pictures. As of last night life happened, so instead of buying all this in bulk to throw together I'm going to have to piece things together, so this is gonna take a little longer than planned. Oh well, maybe this will give me the time to upgrade a few items along the way.
robjh22
'10-14 Exterior Modifications
Oct 9, 2015 02:49 PM
Evil_Capri
Sep 25, 2015 12:56 PM
robjh22
Sep 8, 2015 12:31 PM
