5.0 RWHP?
MPH numbers like those, it should be 12.0's, so it isn't getting off the line hard enough.
Here's a nifty HP and E.T. calculator if you want to play with the numbers.
http://www.allfordmustangs.com/Detailed/619.shtml
_________________
_________________
I'm just basing it on a car that has similar hp numbers along with similar weight. The M3 has more topend but the GT will have quite a bit more torque. Although the M3 with its shorter ratios through the gear box along with the final drive may end up getting the edge here. The M3 with its 8400rpm capability and its 3.85 final drive may have the Mustang at a slight mis-match.
Dave
