2014 V6 + performance package top speed/driveshaft issues
Old Apr 6, 2014 | 10:52 AM
  #141
SpeedyJoe's Avatar
I am going to do it the other way around. First I upgrade the suspension, strut tower brace and sway bars are on the way, and than I'll upgrade the powertrain. I think it is better to really get the power on the ground before adding even more power.
I have the diablosport for the 91oct tune and speed limiter erase.
A friend told me, that there is no real issue with the driveshaft on the V6, they have even the same part no. just like the V8. Even a race mechanic told me, that I don't have to change the driveshaft!?! So what is true?
For me, the driveshaft is last on my list.
Old Apr 6, 2014 | 07:26 PM
  #142
kylerohde's Avatar
Your friend is wrong. The V6 driveshaft is different, which is why the car is limited to 112 MPH.
This is just one of a bunch of videos on YouTube showing what happens when you remove the speed limiter with the stock driveshaft:
Old Apr 6, 2014 | 07:28 PM
  #143
southcarolina12's Avatar
the gt shaft is 2 piece, shorter and has a center support bearing. v6 is one piece and has not center support.
Old Apr 6, 2014 | 08:20 PM
  #144
fdjizm's Avatar
Well , that's true. How can you argue with that logic. Lmao..
for you bro...
Old Apr 6, 2014 | 08:34 PM
  #145
TheDivaDanielle's Avatar
oooh a race mechanic!
Old Apr 6, 2014 | 09:27 PM
  #146
2011 Kona Blue's Avatar
Originally Posted by fdjizm
for you bro...
Cool. Nice time bro! What am I looking at besides a time slip from drag strip? Lol
Old Apr 7, 2014 | 12:47 AM
  #147
SpeedyJoe's Avatar
Well well, so I just have to add the driveshaft to my current order! ... The modding continues...
Old Apr 7, 2014 | 10:04 AM
  #148
Bucko's Avatar
Huh???
Old Apr 7, 2014 | 10:56 AM
  #149
fdjizm's Avatar
Ahh I was reading an old post of us going back and forth lol just had cams installed and went to the track.
Old Apr 7, 2014 | 11:45 AM
  #150
Lol. Nice time!
Old Apr 7, 2014 | 01:22 PM
  #151
killaz05's Avatar
You realize that the V6 has a two piece driveshaft? I have been under my 2014 V6 many times and the two piece drive shaft is always there... begging to be replaced.
Old Apr 7, 2014 | 05:42 PM
  #152
nope its a one piece. ive been under mine many times too since everything i do to my car i do myself. and ive replaced the stock drive shaft and i can take a pic of my stock one and show you its a 1 piece.
Old Apr 7, 2014 | 06:08 PM
  #153
Getportfolio's Avatar
Could it be a production change according to year?
My 11 V6 had a 2 price shaft. (100% positive)
Old Apr 7, 2014 | 06:22 PM
  #154
My 11 3.7 definitely had a 2 piece shaft as well.
Old Apr 7, 2014 | 06:29 PM
  #155
My SHAFT was two piece and had no problem letting me know.
Old Apr 7, 2014 | 06:40 PM
  #156
Ajcruz1's Avatar
^^lol
Originally Posted by Joeywhat
I've been reading up on the driveshaft issues with the recent V6 Mustangs. I've seen a couple folks mention that Ford may have fixed the issue with a redesigned driveshaft, released midway through the 2013 model year. I'm wondering if 1) that is indeed true and if the newer driveshafts are safe at higher speeds, and 2) if Ford raised the top speed for the V6 with performance package, as the ~112 limit is pretty ridiculous (my Focus SE can go faster.....). Can anyone with a 2014 V6 with performance package confirm the top speed? Hopefully a new driveshaft won't be required to hit the road course...and that speed limiter seems low enough to possibly cause issues as well.
OP, I totally forgot until recently I took my performance pack v6 to 120 before the limiter kicked in. I believe those without the PP are limited to 112 mph. Not 100% sure about this but I am sure about mines. There was no tune on it and everything was completely stock as this was at a track shortly after I got it.
Old Apr 7, 2014 | 07:44 PM
  #157
go to page 4 of the " Aluminum Driveshaft - How important is it?" thread. people advertise the stock as being two piece and that you need a one piece but really the stock is a one piece with a slip yoke in the center and you just need another one piece with a slip yoke at the end for higher speeds.
Old Apr 8, 2014 | 11:45 AM
  #158
RubyRedMCA_Beast's Avatar
Doesn't the presence of the slip-yoke mean it is a two piece unit? The slip-yoke connects two pieces?
Old Apr 8, 2014 | 12:58 PM
  #159
:sigh:
A 2 piece means its hinged with a CV joint.
All 1 piece shafts for an SRA have to have a slip yoke. Otherwise going over bumps would beat on either your diff or trans. Think about it.
This is the factory 2 piece from a GT:
From the 2008 Mustang Workshop Manual from Ford:
"The driveshaft must be able to rotate smoothly through a range of acceptable angles and lengths occurring during normal driving conditions."
The GT and GT500 have 2 piece shafts and says "The CV equipped driveshafts control angle and length changes through the CV joins and use a center support bearing for driveshaft stability."
The Manual also discusses the 1 piece used in the 4.0 V6 08 Mustang:
"A 1 piece driveshaft assembly consists of... a driveshaft slip yoke, a driveshaft slip yoke boot...." "The U-joints permit the change in driveshaft angularity with the slip yoke allowing the variance in length."
This is a 1 piece - even though it has a slip yoke:
Old Apr 8, 2014 | 01:58 PM
  #160
AlsCobra's Avatar
A Man Just Needs Some....
Oh my god I can't believe you guys still don't get it. It either has one shaft or two shorter shafts. One piece or two piece.
DONE!!! Anything other than this description on your mustang is WRONG!
How many times can you argue wrong ****?
The end.
