Remote locking
Old Sep 27, 2005 | 08:41 AM
Billy Bob 780's Avatar
Hi, there another question regarding my 95 model gt. Are all mustangs equipped with remote locking ? I was under the impression that they did so bought a remote from EBay, I followed the instructions given to me by the vendor. This involved switching the ignition on and off five times to switch the car into program mode. Nothing happened, so I had a look in the luggage compartment to see if I could see a module and mounted in a bracket I think I found the power locking module. Has anyone got any ideas ?
Old Sep 27, 2005 | 08:56 AM
Tiberius1701's Avatar
95 models have a"program plug" in the left side (driver) trunk area. It is necessary to remove the left side trunk trim panel to access, once the panel is removed you will find a 2 pin gray connector that is normally attached to one of the trunk supports.
To program the remote first turn the ignition on, then short the two pins on the connector in the trunk together briefly, you will find that the locks will cycle to lock and back to unlock. Then just push any button on the remote to program the locks. The locks will cycle to verify programming. jsut turn off the ignition and reassemble the trunk panels and you are done!
Old Sep 27, 2005 | 04:35 PM
Thanks i'll give that a go tomorrow and let you know how it go's
Old Sep 28, 2005 | 09:29 AM
Well I had a look on the LH side and could'nt see any plug, the only looms I can see on that side run to that module in the rear panel and a loom running into the trunk lid. Can anyone attach a photo of this plug? Thanks
Old Sep 28, 2005 | 10:37 AM
The connector/plug would be very visible. If it is not there, then it is quite possible that the car is not equipped with remote entry. The plug is light gray in color
Fedupdave42169
Oct 20, 2015 10:29 PM
dave07
Oct 8, 2015 03:14 PM
Antigini-GT/CS
Oct 5, 2015 09:43 AM
boz
Oct 1, 2015 04:47 PM
PonyMuscletang13
Sep 26, 2015 02:33 PM
