Noise on start up
Noise on start up
My 01, has a noise on start up that is similar to lifter's leak down . Sound like some of the lifter's need to pump up. the engine does this for 10-25 seconds, every time on start up . If the car has been sitting for 2 hours or more.But mod motors don't have lifter's.I use 5 quarts of 5w-20w oil, Motorcraft oil filter. this engine has about 89k on it. What can my problem be? all help appreciated.
I know this is more common in the 3 valves but did you check the timing chains? I know in the trucks when they start to go bad they slap around making a noise. Also I know in the 5.4 trucks the oil pump ( I think) makes a rattling noise on starts. You can check the chains by pulling the valve cover and looking down there with a light and inspect the the plastic shoes ( forgot the actual name.) and see how much wear is in there. I would check the passenger side because that was the worst side on mine.
Good luck
Good luck
Hi, the oil is change every 3k. and the noise started about 6k miles ago. I will pulled the valve cover to check the timing chain. this engine was installed about 18 months ago. and we check the timing chains and installed a new oil pump, before installing the engine. with the low mileage on this engine would not expect it to be timing chains. my 00,F-150 has 296k ,96 t-bird 265k both original engine's. still running strong.
