Noise on start up
Old Dec 28, 2014 | 12:39 PM
td01gt's Avatar
Noise on start up
My 01, has a noise on start up that is similar to lifter's leak down . Sound like some of the lifter's need to pump up. the engine does this for 10-25 seconds, every time on start up . If the car has been sitting for 2 hours or more.But mod motors don't have lifter's.I use 5 quarts of 5w-20w oil, Motorcraft oil filter. this engine has about 89k on it. What can my problem be? all help appreciated.
Old Dec 28, 2014 | 01:32 PM
irishn8's Avatar
Have u tried changing the oil and filter? Is this a recent development?
Old Dec 28, 2014 | 01:35 PM
Sjnagy's Avatar
I know this is more common in the 3 valves but did you check the timing chains? I know in the trucks when they start to go bad they slap around making a noise. Also I know in the 5.4 trucks the oil pump ( I think) makes a rattling noise on starts. You can check the chains by pulling the valve cover and looking down there with a light and inspect the the plastic shoes ( forgot the actual name.) and see how much wear is in there. I would check the passenger side because that was the worst side on mine.
Good luck
Old Dec 29, 2014 | 08:35 AM
td01gt's Avatar
Hi, the oil is change every 3k. and the noise started about 6k miles ago. I will pulled the valve cover to check the timing chain. this engine was installed about 18 months ago. and we check the timing chains and installed a new oil pump, before installing the engine. with the low mileage on this engine would not expect it to be timing chains. my 00,F-150 has 296k ,96 t-bird 265k both original engine's. still running strong.
Mpaps
Oct 11, 2017 08:06 PM
PonyMuscletang13
Sep 26, 2015 02:33 PM
khoy37
Sep 15, 2015 07:10 PM
jim010
Sep 7, 2015 02:40 PM
