Motor wont seat
Old May 15, 2011 | 11:41 PM
Weeman333's Avatar
Motor wont seat
I can't get my motor to come all the way together with my transmission . The top will bolt up , but the bottom has about a half inch to go...the dowel pins are lined up and the motor turns the trans, but will not scoot enough to grab a thread... Any suggestions? Thanks everyone
Old May 16, 2011 | 12:35 AM
AlsCobra's Avatar
A Man Just Needs Some....
What car? What motor? What trans?
Old May 16, 2011 | 12:41 AM
cntchds's Avatar
Did you use the alignment tool to make sure that the clutch is in the correct position? I could imagine your input shaft making it through the clutch, but not being aligned with the pilot bearing, and therefore not letting the tranny go flush. Just a theory.
Old May 16, 2011 | 05:47 AM
yep or if its an auto maybe the tq converter is not set in the trans all the way like it is supose to be.
Old May 16, 2011 | 04:15 PM
Haulin Twinz08's Avatar
I Had the same problem. Mine is a 5 speed and it took pushing the clutch in while pushing in the tranny. Hope this helps
Old May 16, 2011 | 06:52 PM
Weeman333's Avatar
It's a 5 SPd 95 gt. I went to town and got the lil clutch alignment tool and I still couldn't get it to wiggle on there. Said screw it and pulled the trans and the motor. I think the clutch may have to be depressed like you mentioned. Thanks for the help. I'll check back tomorrow
Old May 17, 2011 | 06:20 AM
You loosened all the clutch bolts then installed the line up tool and then tightened all the clutch bolts back up?? Did you replaced the pilot bearing at all when you did the rebuild?
Old May 17, 2011 | 07:44 PM
Weeman333's Avatar
Got it big wiggly style... It needed more of a push than I could get with it in the car
Old May 17, 2011 | 07:45 PM
Weeman333's Avatar
Thanks for your help and advice
Old May 18, 2011 | 06:20 AM
well alright. Congrats!!
Old May 19, 2011 | 12:37 AM
Weeman333's Avatar
Now to get the tranny and motor in as one. I hope I remember where the harness plugs in.
Old May 20, 2011 | 12:28 AM
Weeman333's Avatar
Got it! Now to remember where my harness connects
Road_Runner
Sep 2, 2024 04:46 PM
kponypower
Jun 17, 2020 07:17 AM
yabutt
Oct 23, 2015 01:05 PM
09-gt/cs
Oct 15, 2015 10:03 AM
Evil_Capri
Sep 25, 2015 12:56 PM
