What's this plug for on the Nav Radio?
Old Nov 27, 2009 | 02:06 PM
Jaden's Avatar
Hey guys, I'd like to install an OEM Navigation radio in my 07, but I don't have this third plug on the left. What's this plug for? Is it for the sub woofer on the Shaker systems? Has anyone installed the navigation radio in place of the base CD radio. Here's a photo of the back of my stock radio. Note I don't have the third plug. Thanks for your help.
Old Nov 27, 2009 | 03:20 PM
jim010's Avatar
Interesting. I had a stock radio and upgraded, but I did have the 3rd plug. My radio was a shaker 500.
Old Nov 27, 2009 | 03:57 PM
SteelTownStang's Avatar
Are you replacing a Shaker 500? The nav is compatible with the Shaker 500. Also, once installed, you'll have to have the dealer re-program the radio. It's a little more than just plug and play. I upgraded the system in my FX4, which is simialr, and the third plug was for the sub... Perform a search and you'll find a lot of material on the subject.
Old Nov 28, 2009 | 05:47 AM
Beargap's Avatar
I believe thst is right...that 3rd plug is for the subs. You can try and see if everything works OK without that, but I do recall the Nav option from Ford saying "Shaker 500 required". I also recall from when I put mine in that there was a programming question about whether the car had subs, so I suspect you can run it as a direct replacement for the stock radio if it is programmed OK.
=Vic=
Old Nov 28, 2009 | 08:44 AM
Jaden's Avatar
Thanks guys. I have the base radio, not the Shaker 500. Hopefully it will work without the sub woofer.
Old Nov 28, 2009 | 11:38 AM
bee bop's Avatar
I believe that the plug in question is for rear seat entertainment systems interface. We all know that the sub in the 1000 is in compatible with the nav and this unit was avaliable in most of the SUVs.
Old Nov 29, 2009 | 08:26 AM
Jaden's Avatar
Has anyone tried this before? Upgrading the base radio to the navigation unit. I'm worried now that the radio might not work without the third plug. Also, I've been reading about problems with a speed sensor error. Any insight into that? Thanks.
Old Nov 29, 2009 | 02:25 PM
data174's Avatar
The plug you have in question controls the power to the subs on the shaker 500 and 1000.
The speed sensor problem was one of the problems when trying to install the OEM navigation unit on the 2005-2007 Mustangs.
The navigation unit will have to be programmed for the Mustang and Ford will not be able to program the unit for you.
Look for the thread on installing a navigation radio on a 2005 Mustang. You will find it to be very informative.
Cheers
Old Dec 1, 2009 | 07:44 PM
cubican's Avatar
The plug is for the subs, and yes it will work just fine . in some 05-07 you will get a error window on the screen just press ok and everything works great. Depending on the car that is out off you will need to program the stereo ,but test it first many time it will work just fine. I have done over 40 installs on mustangs and Im testing the new 2010 hard drive on my 05 mustang.working great.
Old Dec 1, 2009 | 07:56 PM
cubican's Avatar
Heres a pic of the new 2010 nav on a 05 mustang
Old Dec 1, 2009 | 08:01 PM
Jaden's Avatar
Hey Cubican, that's awesome. Do you get any error messages with the 2010 nav? I really want to avoid getting the error message when you first start up. Thanks.
Old Dec 1, 2009 | 08:16 PM
cubican's Avatar
On the 2010 there is no error mas but these stereos work with the computer speed sensor for the nav portion of it ,Im still working on getting the bugs out ,but I got everything to work so far. you do need an amp and a custom harness, but I can get that.
Old Dec 2, 2009 | 03:53 AM
mco05gt's Avatar
Cubican, how much to do the whole thing? If I wanted one could I get it through you? Hard to find on ebay!
Old Dec 2, 2009 | 07:33 AM
cubican's Avatar
I can get the amps and harness( new), and the special antenna, as for the radio is much harder to find. Pm me I do have one complete system. That I can sell. not cheep but woth it.
Old Dec 26, 2009 | 06:54 PM
302svt's Avatar
Any more pics of this.
CNFLCTD
GT350
Aug 4, 2017 07:08 AM
oneeyedgiant
Nov 16, 2015 12:23 PM
PonyMuscletang13
Sep 26, 2015 02:33 PM
