SIRIUS PLUG AND PLAY FOR 05 up Mustang
Old Sep 4, 2011 | 03:05 PM
  #221
Col.Hogan's Avatar
Ok, I was directed here from another post on this forum. I currently have an xm subscription and using a commander xt and want to use a xm unit like the xmdirect 1000 tuner that will work with a sat ready head unit. I currently have a shaker 500 that the tsb has been done. Is there a way yet to use the shaker 500 head as a control for an xm unit like the Sirius unit from the factory. Any assistance would be greatly appreciated.
Old Jan 20, 2025 | 12:17 PM
  #222
05stangkc's Avatar
Updated For Bad Links.
Useful Info For Those Adding a Factory Sat Radio From Donor Car
01/20/2025
Use this Info to Determine you Radio Number! All Radios may not be Compatible with the Unit!
415-00 Information and Entertainment Systems 2007 Mustang GENERAL PROCEDURES Procedure revision date: 01/26/2007
Audio Unit Part Number Retrieval
NOTE: The audio unit must be in radio tuner (AM/FM) mode to retrieve the part number.
  1. Turn the audio unit on.
  1. Press and hold preset buttons 3 and 6 for 3 seconds. The speaker walk-around test will begin.
  1. Before the speaker walk-around test is complete, press preset button 6.
  1. Press the TUNE UP button. This will either directly indicate the part number or it will cause the audio unit to scroll through config 1, config 2, EEPROM, and the part number information.
    • If the audio unit scrolls through the information, Step 4 may need to be repeated until the audio unit part number can be recorded.
  1. Record the audio unit part number.
  1. Turn the audio unit off.
Satellite Radio Receiver Electronic Serial Number (ESN) Retrieval
Audio Systems Without Navigation
  1. Operate the audio system in satellite radio mode.
  1. Press and hold the AUX button and preset button 1, simultaneously.
    • The satellite radio receiver Electronic Serial Number (ESN) will be displayed on the screen.
  1. Record the satellite radio receiver ESN .
  1. Turn the audio system off.
Audio Systems With Navigation
  1. Turn the audio system on.
  1. Press the MENU button.
  1. Select the SYSTEM INFO tab.
  1. NOTE: The satellite radio receiver ESN is shown on the lower left corner of the screen with the text "SR ESN:".
muslenutz
Sep 2, 2007 05:36 AM
Jon_Purdy
05-09 Interior and Audio Mods
56
Aug 17, 2006 11:56 AM
sodaman
Jun 11, 2006 08:50 PM
78Mach1
Nov 16, 2004 09:03 PM
