SIRIUS PLUG AND PLAY FOR 05 up Mustang
Old Oct 9, 2006 | 10:53 PM
  #61
daz72's Avatar
please notify me too
please add me to the list.
I'm interested to hear how much this upcoming Nav unit will cost.
But in lieu of that, would be good to add Sirius to my Shaker 1000
thanks
Old Oct 10, 2006 | 05:14 PM
  #62
05stangkc's Avatar
Use this Info to Determine you Radio Number! All Radios may not be Compatible with the Unit!
415-00 Information and Entertainment Systems 2007 Mustang GENERAL PROCEDURES Procedure revision date: 01/26/2007
Audio Unit Part Number Retrieval
NOTE: The audio unit must be in radio tuner (AM/FM) mode to retrieve the part number.
  1. Turn the audio unit on.
  1. Press and hold preset buttons 3 and 6 for 3 seconds. The speaker walk-around test will begin.
  1. Before the speaker walk-around test is complete, press preset button 6.
  1. Press the TUNE UP button. This will either directly indicate the part number or it will cause the audio unit to scroll through config 1, config 2, EEPROM, and the part number information.
    • If the audio unit scrolls through the information, Step 4 may need to be repeated until the audio unit part number can be recorded.
  1. Record the audio unit part number.
  1. Turn the audio unit off.
Satellite Radio Receiver Electronic Serial Number (ESN) Retrieval
Audio Systems Without Navigation
  1. Operate the audio system in satellite radio mode.
  1. Press and hold the AUX button and preset button 1, simultaneously.
    • The satellite radio receiver Electronic Serial Number (ESN) will be displayed on the screen.
  1. Record the satellite radio receiver ESN .
  1. Turn the audio system off.
Audio Systems With Navigation
  1. Turn the audio system on.
  1. Press the MENU button.
  1. Select the SYSTEM INFO tab.
  1. NOTE: The satellite radio receiver ESN is shown on the lower left corner of the screen with the text "SR ESN:".
File Type: pdf
Old Oct 10, 2006 | 06:43 PM
  #63
rocket88's Avatar
I have 6R3T 18C8 156E
Old Oct 11, 2006 | 06:27 PM
  #64
GATORBAIT9696's Avatar
ok I am lost, how do I know? and is this for the nav or the sirus?
Old Oct 11, 2006 | 06:31 PM
  #65
rocket88's Avatar
It's for the Sirius, we won't know until it's released.
Old Nov 2, 2006 | 02:50 PM
  #66
05stangkc's Avatar
Please See post 62 to get part number from your radio.
First Sirrus units to arrive Monday
pics to follow
KC
Old Nov 2, 2006 | 11:17 PM
  #67
sodaman's Avatar
KC are you emailing us on availability in order of interests, or should I call you with info etc? Just want to make sure I am still in line for this item. Do we have an idea on cost yet? Thanks for any info KC
Old Nov 5, 2006 | 02:04 AM
  #68
Cliff's Avatar
Please notify me when available. Thanks!
Old Nov 5, 2006 | 09:07 AM
  #69
sodaman's Avatar
He has some already, he has not unpacked them yet. He will be doing so this week and taking pictures of the whole set up. He said that ford in there infinite wisdom has not included any kind of instructions on how to install or operate. So if anyone out there can get this kind of info please chime in. Also those interested look up your radio id following instructions in post #62, this will let him know if your radio will work etc. I am sure KC will be posting on this this week. Thanks for any info on sirrus install, if anyone can get some kind of manual/install instructions. Otherwise looks like I will be playing around with it.
Old Nov 6, 2006 | 01:27 PM
  #70
05stangkc's Avatar
[img=http://images3.pictiger.com/thumbs/1d/da1ff0bd94059a1afabe8f08d6b6f61d.th.jpg]
Here is the Kit.
1 control Box.
1 Magnetic Antenna
1 Wire Concealer & Adhesive
1 Harness.
I will add these to Hotsheets Asap!
KC
These Units do not have Ipod Jack. I believe another Sub Harness will be Available in the Future to support that. No Guarantees on that though.
Old Nov 6, 2006 | 01:55 PM
  #71
WB2005GT's Avatar
KC,
I need a little verification. Is there a Sirius receiver in the control box? It looks like an under dash receiver. If it is not, what type of receiver connects to the control box? I assume that this kit allows you to control the Sirius using the radio buttons (change channels, display, menu, etc.). If all it does is allow you listen to a portable Sirius through the Aux button (and not be able to change channels, etc.), that is the same thing that the PIE FRD04 Aux Adapter does. I apologize if you already posted this info and I missed it.
Old Nov 6, 2006 | 02:37 PM
  #72
05stangkc's Avatar
This is a Sirius Unit. It is Plug and Play. With Activation Of Course. It will be controled by your Radio Controls.
Old Nov 6, 2006 | 02:38 PM
  #73
WB2005GT's Avatar
Sweet, thanks
Old Nov 9, 2006 | 07:23 AM
  #74
AvtoLubitel's Avatar
bump. Any news?
Old Nov 9, 2006 | 07:53 AM
  #75
Couper93's Avatar
Cost?
Old Nov 9, 2006 | 08:57 AM
  #76
05stangkc's Avatar
The First sirius Unit is on it's Way to Sodaman. I would Like to see a couple of Successful Installs before I start Pushing them. I would hate to ship a bunch of units before I get some Customer Feedback. I want my Customers to know exactly what they are Getting. Pricing is in my Hotsheets!
KC
Old Nov 9, 2006 | 03:27 PM
  #77
rocket88's Avatar
KC, Is the factory style antenna availble?
Old Nov 9, 2006 | 04:41 PM
  #78
sodaman's Avatar
Bump on that KC, I may want to try and go with factory antenna, can you order them yet. A freind of mine used one of the magnetic antennas on her honda, and she says it has scratched it up a little. If not I may see how good reception is with it inside the car. Thanks
Old Nov 9, 2006 | 10:01 PM
  #79
05stangkc's Avatar
I have the Factory Antenna Setup on order to check out. The Factory Sirius Mounts the Reciever in the Trunk. The Accessory will be under The Dash Area I presume due to wiring Length. Of Course they are Backorderd BTW.
Old Nov 10, 2006 | 03:12 PM
  #80
sodaman's Avatar
Cool KC, please let me know when you can get the factory antenna, I am sure I will try to go factory if it will all work together. We shall see I guess. Thanks for your great service as always. Chat at you soon.
